12-27-2024 04:56 AM
I have this Configuration on my MultiLayerSwitch (Topology in figure):
version 16.3.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname MLS
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
ip cef
ip routing
no ipv6 cef
username cisco secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
ip domain-name rosanna.com
spanning-tree mode pvst
interface GigabitEthernet1/0/1
no switchport
ip address 10.0.0.3 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet1/0/2
switchport access vlan 3
switchport mode access
interface GigabitEthernet1/0/3
switchport access vlan 4
interface GigabitEthernet1/0/4
switchport access vlan 5
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan3
mac-address 0060.2f39.d601
ip address 192.168.3.1 255.255.255.0
interface Vlan4
mac-address 0060.2f39.d602
ip address 192.168.4.1 255.255.255.128
interface Vlan5
mac-address 0060.2f39.d603
ip address 192.168.4.129 255.255.255.128
interface Vlan100
mac-address 0060.2f39.d604
ip address 192.168.100.1 255.255.255.0
router ospf 10
log-adjacency-changes
passive-interface GigabitEthernet1/0/2
passive-interface GigabitEthernet1/0/3
passive-interface GigabitEthernet1/0/4
passive-interface Vlan100
network 192.168.3.0 0.0.0.255 area 0
network 192.168.4.0 0.0.0.127 area 0
network 192.168.4.128 0.0.0.127 area 0
network 10.0.0.0 0.0.0.7 area 0
network 192.168.100.1 0.0.0.0 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
password 7 0822455D0A16
login
transport input ssh
line vty 5 15
login
transport input ssh
end
Please, explain me WHY my Management VLAN (VLAN 100) doesn't work for ssh connection from hosts.
I'm a little confused right now.
Solved! Go to Solution.
12-27-2024 07:20 AM
When you create an interface vlan on the switch but you dont use it, the vlan will stay down. As long as you have the vlan assign to a trunk or to an access port, it will come up. Your vlan 100 is down.
Vlan1 unassigned YES unset administratively down down
Vlan3 192.168.3.1 YES manual up up
Vlan4 192.168.4.1 YES manual up up
Vlan5 192.168.4.129 YES manual up up
Vlan100 192.168.100.1 YES manual up down
MLS#
MLS#
As soon as you associate one interface to the vlan 100, it will come up
GigabitEthernet1/1/4 unassigned YES NVRAM down down
Vlan4 192.168.4.1 YES manual up down
Vlan100 192.168.100.1 YES manual up up
MLS#
%LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to up
and you are able to ping it.
If you dont want to have a PC on vlan 100. you can use loopback interface instead. Loopback will always stay up dont matter what.
12-27-2024 04:58 AM
Did you generate rsa key
MHM
12-27-2024 04:59 AM
yes, I did it.
12-27-2024 05:31 AM
From where you are trying to access exactly?
You have passive interface on vlan 100.
Can you ping vlan 100 from host ?
12-27-2024 05:50 AM
ok. I'm trying to access from host in Inter-vlan routing on MLS SVIs. PC0 is not pinging MLS int vlan 100.
I removed the passive-interface on int vlan 100.
vlan 100 is still not in my routing table of MLS. What am I not considering?
12-27-2024 05:58 AM
Didi you creste vlan 100?
Vlan 100
On mls
12-27-2024 06:03 AM
yes. I created vlan 100. My vlan dat:
MLS#show vlan b
VLAN Name Status Ports
1 default active Gig1/0/5, Gig1/0/6, Gig1/0/7, Gig1/0/8
Gig1/0/9, Gig1/0/10, Gig1/0/11, Gig1/0/12
Gig1/0/13, Gig1/0/14, Gig1/0/15, Gig1/0/16
Gig1/0/17, Gig1/0/18, Gig1/0/19, Gig1/0/20
Gig1/0/21, Gig1/0/22, Gig1/0/23, Gig1/0/24
Gig1/1/1, Gig1/1/2, Gig1/1/3, Gig1/1/4
3 VLAN0003 active Gig1/0/2
4 VLAN0004 active Gig1/0/3
5 Data active Gig1/0/4
100 Gestione active
1000 Nativa active
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active this is also my routing table
10.0.0.0/29 is subnetted, 1 subnets
C 10.0.0.0 is directly connected, GigabitEthernet1/0/1
O 192.168.0.0/24 [110/2] via 10.0.0.1, 01:16:37, GigabitEthernet1/0/1
O 192.168.1.0/24 [110/2] via 10.0.0.1, 01:16:37, GigabitEthernet1/0/1
O 192.168.2.0/24 [110/2] via 10.0.0.1, 01:16:37, GigabitEthernet1/0/1
C 192.168.3.0/24 is directly connected, Vlan3
192.168.4.0/25 is subnetted, 2 subnets
C 192.168.4.0 is directly connected, Vlan4
C 192.168.4.128 is directly connected, Vlan5
12-27-2024 06:15 AM
OK.
Can you please zip your PacketTracer file and attach here? I can take a look
12-27-2024 06:23 AM
12-27-2024 07:20 AM
MLS#
MLS#
MLS#
12-28-2024 02:02 AM
ok, thank you!
12-27-2024 11:18 PM
Hi @rosanx
Fix reachability and make sure you're able to ping 192.168.100.1. Once you fix reachability, still you won't be able to SSH.
You can telnet, but you have disabled telnet by using transport input ssh under vty config.
For SSH to work, you need username and password. For that, you should point the VTY to use local user database or to some AAA.
Use the below commands to point the VTY to use local user database
line vty 0 4
login local
12-28-2024 03:22 AM
@rosanx once you fix reachability, make sure you enable local user in vty for ssh to work.
line vty 0 4
login local
12-28-2024 05:18 AM
Helllo
it look like your only ospf adjacency from that l3 sw it to rtr1 via gig1/0/1
So you just need to allow that link to establish and passive the rest of the l3 svi interfaces
Try the following:
crypto key zerosize rsa
crypto key generate rsa label OSPF general-keys modules 2048
ip ssh enable
ip ssh version 2
Router ospf 10
passive interface default
no passive interface gig1/0/1
12-30-2024 03:17 AM
Thank you all!
