MULTILAYER VLAN ROUTING
yujinan805
CAN SOMEONE SOLVE MY PKT
Hello @yujinan805
All is good with this file under tp_8.zip !
All PC can ping each others... what is the problem ?
Best regards
7 Replies 7
yujinan805
THIS, ALL THE DEVICES MUST BE CONNECTED
THIS MY CISCO PACKET FILE
@yujinan805
Do you mean, inter-vlan routing?
Do you have the command "ip routing" in your multilayer switch?
You can share your PKT file. Just zip It first
yes, inter vlan routing, this is my pkt
this cannot be connect this, sirthis cannot be connect this, sir
Hello @yujinan805
Best regards
Hello @@yujinan80
see attached for working PT file
Kind Regards
Paul
yujinan805
ty its work now hehe
