Multilink frame and frame/ATM internetworking?
dtangent
Is there any official specification that anyone knows regarding MFR and frame/ATM internetworking compatibility?
In other words, if you have a CPE running MFR to a FR/ATM switch, and from that switch you have an ATM connection to another CPE, will that work? Regular FRF.8 works fine, but since one of the requirements with MFR is that the remote site needs to terminate the MFR traffic, I am assuming it would actually have to be done on the FRF.8 capable switch in this case. I am unsure whether a FRF.8 capable switch can do it.
mmellet
Level 3
Level 3
Check the below URL having the information about the Multilink frame and frame/ATM internetworking.
http://www.cisco.com/en/US/products/hw/switches/ps525/prod_release_note09186a0080080d03.html
