Multilink Frame relay
mailaglady2
I have two bundle links and they both up but my bundle interface protocol is down. Here are my configs below, hat could be a problem?
interface MFR0
no ip address
frame-relay lmi-type ansi
interface MFR0.100 point-to-point
ip address 165.149.120.1 255.255.255.252
snmp trap link-status
frame-relay interface-dlci 100 IETF
interface Serial0/3/0
no ip address
encapsulation frame-relay MFR0
clock rate 5300000
no arp frame-relay
interface Serial0/3/1
no ip address
clock rate 5300000
no arp frame-relay
DUT_3825#sh ip int br
GigabitEthernet0/0 192.1.1.1 YES NVRAM up up
GigabitEthernet0/1 155.239.247.103 YES NVRAM up up
Serial0/3/0 unassigned YES manual up up
Serial0/3/1 unassigned YES manual up up
MFR0 unassigned YES unset up down
MFR0.100 165.149.120.1 YES manual down down
Loopback0 1.1.1.1 YES NVRAM up up
Giuseppe Larosa
Hello Lawrence,
please re-enable arp frame-relay on the links.
Some mounths ago someone had the same problem after long troubleshooting the problem was this.
By the way in CCO examples this command is not listed
Hope to help
Giuseppe
Done, re-enabled but still no luck.
I did not configure the router as a dce that was the reason... I am sorted now thanks..
