Multilink frame relay
rlangley
I have an existing frame relay T3 on a serial interface with multiple existing PVCs on sub-interfaces. Is it possible to configure 2 PVCs as additional sub-interfaces on this frame relay T3 and configure them as a multilink frame relay bundle without affecting the existing sub-interfaces (mostly T1 PVCs)? The router is a 7606 with IOS 12.2(18)SXD. The remote router is expected to be an Adtran 3305 router with multilink frame relay on two T1 circuits.
Robert Langley
Oso Grande Technologies, Inc.
langley@osogrande.com
505-345-6555
attrgautam
Level 5
Level 5
Not sure if you can do that. To make a link a part of MFR, you would need to specify encapsulation which wou will not be able to do on a FR subinterface.
Hello Robert,
not sure if this is an option for you, but you could try Multilink PPP over Frame Relay, the configuration would look something like this:
interface Multilink1
ip address 192.168.1.1 255.255.255.252
ppp multilink
multilink-group 1
interface Serial0/0
encapsulation frame-relay
no frame-relay inverse-arp
interface Serial0/0.101 point-to-point
frame-relay interface-dlci 101 ppp virtual-template1
interface Serial0/0.102 point-to-point
frame-relay interface-dlci 102 ppp virtual-template1
interface Virtual-Template1
ppp multilink
multilink-group 1
You could even configure ppp authentication:
ppp multilink
multilink-group 1
--> ppp authenticatio chap
--> username Multilink password CISCO
HTH,
GP
crivera
I don't think you will have issues with the other pvcs already configured. Be careful with special configurations you have to make for routing protocols like ospf when in runs over a point to multipoint network.
