multilink frame relay
vyam
What's the maximum number of T1s that can be aggregated into a multilink on a 7609?
I have a client that wants to bundle two bundles of 8T1s together. Is this possible? If yes, what is the configuration?
-Vev
cpubob
I cannot find a hard number, but the cli will let you specify 255 as the maximum number of links on the mlppp interface.
As for the setup, just do it like a normal mlppp setup,
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804a40f9.html
Thanks for the help. This doesn't exactly answer the question, but it does help. I'll try it out to see if the router will take 16 T1s.
paolo bevilacqua
Which exact hardware do you have? The common limit is 12 links per bundle.
