09-12-2006 06:46 AM - edited 03-03-2019 01:58 PM
Switching to multilink ppp for our two serial interfaces, T1 lines, on a 3725 router with 12.3(7)T IOS. I understand that the ACLs we currently have applied to the serial interfaces get applied instead to the logical multilink interface. What about the CBAC, NAT, and cache-flow commands we currently have applied to each serial interface -- do they also now get applied to the logical multilink interface?
The commands are:
ip inspect <fw name> out
ip nat outside
ip route cache-flow
(Can't find answers in TAC docs, at least from docs my searches turned up.)
Thanks.
Solved! Go to Solution.
09-12-2006 06:50 AM
All commands should be applied to the multilink interface since this interface will contain the IP address information.
The bundle serials won't have any IP information and they will function just as layer2 interfaces hence any IP service will be discarded.
Please rate helpful posts.
09-12-2006 06:50 AM
09-12-2006 08:20 AM
Great, thanks. We're all set then, hopefully :-)
