Multilink : Reliability Problem
bapatsubodh
We are having STM contoller on 7500 series router. We have 4, 2 mbpls point to point links from location A to location B. We have created a logincal multilink interface Mu1 and all 2 mbps links are member of this multilink interface. Problem we are facing is that reliability of mu1 interface goes down to 130/255 ( approximately 50 % ). We removed membership of links one by one, what we found is that when mu1 has only one member it works fine. We tested for all links seperately it worked fine, but when links were clubbed together lots of input errors are coming.
Any idea how to debug this problem.
Any link on cisco.com or experience in similiar line, please share, would appreciate.
Thanks in advance
Subodh
kerek
Level 4
Level 4
Have you used mppp or mfr?
Can you post the config?
Krisztian
We are using following conf for serial link
ppp multilink
ppp multilink group 1
and for multilink
ip address ***** /24
ppp multilink group1
this is the minimum configuration which we are using.
Please revert back
Thanks and Regards
Subodh
Has the mlppp established correctly?
show ppp multilink
Has the cef (dcef) enabled?
Alternatively try to configure mfr.
Krisztian
