Multilink two 64 K lines
sudeesh79
Hi all
We have two sites connecting with two 64K
seperate leased lines.I want to configure multilink these two lines.I dont want t0 use any routing protocols
.Please tell me the configuration.
Thanks in advance
Sudeesh
8 Replies 8
amit-singh
Level 8
Level 8
Please go through the link, it will be handy.
http://www.cisco.com/warp/public/471/multilink_bundles.html
regards,
-amit singh
hai Amit
The link which you sent tells multilinking one serial
interface and one Bri int .Can u tell me any link
defining multilinking with Two serial interfaces.
Thank u
Regds
Sudeesh
The config is exactly the same as on serial interface. You dont have to do anything special.
interface Multilink1
ip address 192.168.19.6 255.255.255.0
no cdp enable
ppp multilink
multilink-group 1
interface Serial1
no ip address
no ip directed-broadcast
encapsulation ppp
no fair-queue
ppp multilink
multilink-group 1
interface Serial2
no ip address
encapsulation ppp
no fair-queue
ppp multilink
multilink-group 1
HTH,
-amit singh
Hi thank you Amit
And I want to configure Isdn as backup ,so in which int should I apply the backup int .Is it under Int multilink 1? .If I am using static routes what should
be the routes .
regds
Sudeesh
To use ISDN as back, give the back up interface command unset multilink interface. As far as our multilink interface is up we are going via serial and the moment it goes down the ISDN should fire up.
The static routes that you will use would be something
ip route 0.0.0.0 0.0.0.0 next hop multilink ip
or
ip route 0.0.0.0 0.0.0.0 multilink 1
and for ISDN
ip route 0.0.0.0 0.0.0.0 bri0 <+++ ISDN interface
HTH,
-amit singh
Hi amit
We are also using voice .could u tell me what are the
additional configuration for voice traffic .
Suppose I want to pass data traffic to s0/0 and
voice to s0/1.could u heip me to configure
in this way .
Sudeesh
Hi Sudeesh,
One point I missed out in our static route defination, just use the default route for ISDN as the floatic static route. I.e define it in this way
ip route 0.0.0.0 0.0.0.0 bri0 100 <++ this is administrative distance whihc will make this route as floating static route,
Also for carrying out your voice traffic completely on a diff interface you can use PBR i,e policy routing. This will route the traffic matched on the intersting traffic and will take the exit interface as defined by you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800ca590.html
HTH,
-amit singh
Hi Amit
Thanks for your quick information
Regds
Sudeesh
