Multilink
hectorsandoval
I have two questions about PPP Multilink.
How many Multilinks can I configure in a router cisco 3845 ?
also How many link can I put inside a Multilink ?
5 Replies 5
Goutam Sanyal
Level 4
Level 4
Hi Hector Sandoval,
As per my knowledge you can configure from 1 to 2147483647, and I have bundled 3 individual (Same ISP, 1x64 Kbps and 2x128Kbps) link perfectly.
Goutam
Pls rate if it helps u!
1.Strangely i found the multilink group range starting from 0 till 214748364. I have mentioned the link also below for reference.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ft_mlppp.html
2.But when i tried using command
"interface multilink 0" on Cisco 3745 with 12.4 IOS , it gave error , & using tab it shows the range as mentioned by Gautam 1 to 2147483647
3.Also i found the option "Multilink PPP Minimum Links Mandatory" to form multilink ,as well there is option of maximum links in a multilink bundle.
commands for same are
"ppp multilink max-links links"
"ppp multilink min-links links"
And here it shows the range as 0 to 255, it means these number members of links can be added in a multilink group.
4.Well , practically i have added 4 links suceessfully on Cisco 10000 router.I am sure we can add more links.
5.None of the command referecne mentions the exaxt number of members , which can be added in a single multilink bundle.
HTH..rate if helpful..
I need to create another Multilink2 with 2xE1 for a new client. I want to be sure this is possible before we buy the hardware.
Also on my 2801 I don't see any Multilink 0 as you reference on pint 2, this is what I see:
rt-2801(config)#interface multilink ?
<1-2147483647> Multilink interface number
Thanks for your response, right now I have one Multilink1 with 6xE1, and I need to create another Multilink2 with 2xE1 on the same router, I have read a document that comments that you can have 8 links per bundle. See the attach document.
I think picture is clear now..you should be able to create one more multilink then..
