7206vxr doesn't detect PA-E3 card
vijay sanwal
This PA-E3 card works fine in another 7204 but gives error in 7206VXR.
We also upgraded the IOS from AdvIPServicesK9 124-15.T7 to 12.4(4)XD10.
Besides PA-E3 which we are trying to install, this device has:
NPE-G2
C7200-JC-PA
SA-VAM2+
Error file attached.
Edison Ortiz
NPE-G2 is not compatible with a number of Port Adapters. Please take a look at this Field Notice and verify if the Port Adapter is listed as compatible.
http://www.cisco.com/en/US/ts/fn/620/fn62535.html
HTH,
__
Edison.
Please rate helpful posts
Already checked. PA-E3 is compatible and I am using an appropriate IOS.
I suggest opening a TAC case.
__
Edison.
