Multilinking Frame Relay and other WAN Connections
emillington
Can you multilink different speed circuit without maxing out the slowest speed circuit?
Would it be better to use a routing protocol for load balancing, like EIGRP for this?
Edward
mheusinger
Level 10
Level 10
yes you can bundle several FR PVCs
Have a look at "Multilink Frame Relay (FRF.16)"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804554eb.html
The recommendation is however to have all PVC at the same speed.
With EIGRP and "variance" you have another option for load balancing, which also works.
Be aware that CEF also plays a role when it comes to load balancing. Default is per destination load balancing, which makes sense usually. In case you have only one data stream it could mean however that only one interface/PVC is used.
Hope this helps
Martin
Thanks Martin!
I saw that one in my research, but I am wondering about using a variety links.
Example, a wan 256K link, FR, BRI and so on. In my case, a FR 128/256 and a wan 512K link.
