verify dmfr on 7500
mforthman
Is there a way to verify distributed Multilink Frame Relay is running on a 7500? PPP multlink has a "show ppp multilink" command to disply this info.
mheusinger
Level 10
Level 10
for Fr there is "show frame-relay multilink".
Have a look at
"Distributed Multilink Frame Relay (FRF.16)"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804554ee.html
Hope this helps
Martin
I have looked at that document. What I am looking for is a command that shows something similar to the "sh ppp multilink". It specifically says the "Bundle is Distributed".
From another slant, could you be doing MFR on a 7500 and it NOT be doing DMFR?
Multilink3, bundle name is group3
Bundle up for 02:05:39
1 lost fragments, 0 reordered, 0 unassigned <---------- [1]
14 discarded, 15 lost received, 1/255 load <----------- [2]
0x0 received sequence, 0x0 sent sequence
Member links: 1 active, 0 inactive (max not set, min not set)
Se6/3/0/1:0, since 02:05:40, no frags rcvd, 5760 weight, 1496 frag size
