Multiple GRE tunnel question
ColForbin
I’m just making sure on this. If you have two GRE tunnels whose source is the same interface, both MTU would still be 1476 correct?
For instance
Interface gig 1/0/1
ip addr 192.168.1.1 255.255.255.252
tunnel 1
ip mtu 1476
ip tcp adjust-mss 1436
tunnel source 192.168.1.1
tunnel 2
ip mtu 1476
and the destinations would be different.
Thanks. Just a sanity check I hope.
Joseph W. Doherty
9 Replies 9
Joseph W. Doherty
Correct.
This second post
We try hard inform you this wrong design but I dont know maybe you want to test
But in real network that so so bad design use tunnel IP as source of other tunnel
One of point you will face is high overhead of IP
Here there two tunnel header so sure MTU not same mtu of second must be lower than first with at least 40 bytes
To be sure run wireshark see how traffic look like.
MHM
Was this reply meant for another thread?  I ask, because both tunnels are using the physical interface IP.
Interface gig 1/0/1
tunnel 1
tunnel 2
Why 40, as the usual GRE header uses 24 bytes (the GRE IP header and GRE header)?
Check IP he use tunnel one IP use as tunnel source
Why 40 bytes ? Gre normal is 24 but it not secure if we use iPsec options with it so at least we need 40 bytes.
To check let him try use wireshark' let him see how traffic pass how GRE look like'
Engineer without wireshark like blind
MHM
I don't see, in OP, what tunnel IPs are, as it appears that wasn't provided, so, I'm confused with what you're describing.
Why 40 bytes ? Gre normal is 24 but it not secure if we use iPsec with it so at least we need 40 bytes.
Fully agree that GRE/IPSec overhead is more than 24 bytes.  However, in my experience often the overhead is more than 40 bytes; believe Cisco recommends allowing for 100 bytes.  (Interesting overhead calculator mentioned in https://community.cisco.com/t5/security-knowledge-base/ipsec-overhead-calculator-tool/ta-p/3162650.). Also, agree GRE, alone, isn't secure, but OP didn't mention such a need.
You certainly could do that, but often when checking MTU, I find that might be answered using ping with specific packet sizes in conjunction with setting DF.
Historically, you provide great lab results, so, wondering, could you demonstrate the issues you've describe?
ColForbin
Just so there’s no confusion. A previous post I discovered a gre tunnel that was using another gre tunnel IP as its own source. So i posted about that because it was up and passing traffic. And my instincts were this was a bad design and was looking for confirmation.
This second post was after I fixed that config, which by the way resulted in a small blip only, so it was a fast fix…but once I had the two separate tunnels configured with the same source IP, so the same physical interface, I didn’t see any problems, it just got me thinking about the mtu. This instance they are both just gre. I was pretty sure each tunnel is separate so each one should have an mtu of 1500-24=1,476 and it appears that bears out..
Thanks, now @MHM Cisco World 's initial reply in this thread, and its initial "This second post", makes much more sense, as he was thinking you were still doing what you originally did.
Sorry again you wrong
GRE header is not 24 bytes
GRE header if it contain Key (add key to tunnel) then it will be 28 bytes ... and so on
Dont Use fix value check by extended ping or wiresharke there is no magic way to see how much mtu you need
on
I suspect OP wasn't planning on enabling GRE options that increase the GRE header, and if not, GRE header minimal is 4 octets plus IP header, which also has optional header fields that can extend its size from its minimal of 20 octets up to 60 octets.
Interestingly, the RFC 1701 GRE header can range is size from 4 octets to 20.
RFC 2784 eliminated many of the options (including key) so its size is from 4 to 8 octets.
RFC 2890, brought back many GRE options (including key) and octet size can range from 4 to 16.
Notwithstanding the above, again, IP headers can size from 20 to 60 octets, ditto for TCP headers.  So, static settings of IP MTU and adjust MSS are pointless (especially as they can vary by flow), but are they pointless?
In real world, usually, GRE header, IP header and TCP header are their minimal values.  When they are not, either traffic will be fragmented (which we're trying to avoid) or PMTUD will dynamically reduce flow's MTU (which is good, but it has its own pitfalls we're trying to avoid too).
The only "magic" is, using typical hard set values typically is advantageous most of the time.
BTW, the classical Cisco document for how to use IP MTU and adjust MSS, also just describes GRE has 24 bytes overhead.
