Multiple ISP connections with fault tolerance
TalonKarrde
Hi All,
We have a customer who would like to have three seperate ISP's providing internet services to a single office for extreme fault tolerance. I am assuming these are all going to be DSL connections with ethernet handoff to the router.
Load balancing is not requested, and the key goal is to keep local users on the Internet at all times, I dont know if NAT is to be used in this scenario.
I would like to find out is there an automatic way to fail over to the various connections in this setup. I understand that BGP could be implemented in co-operation with the ISP's involved, but something tells me it will be messy and complex to do this.
Perhaps object tracking is a solution as was suggested in another post I have going at the moment.
If we were to use BGP, what sort of router would be required to handle this?
Comments and suggestions would be greatly appreciated..
Cheers
s.jankowski
Level 4
Level 4
It all depends on your requirment, Like number of users, hours they are using and how many bytes you need to download and upload the datas. Make it short and check with cisco product support page depends on your requirment.
matthiaskoehler
i have implentented a similar config not too far ago. This config uses 2 Dialer (i this case a DSL and ISDN interface). If for any reason one specific IP (for example your main ISP Gate) is reachable anymore all the traffic will be routed through the 2nd Dialer.
I sould be very easy for you to make the needed changes.
Matthias Köhler
ip dhcp excluded-address 192.168.0.1 192.168.0.199
ip dhcp pool prod1
import all
network 192.168.0.0 255.255.255.0
dns-server 145.x.x.x.195.20.13
default-router 192.168.0.1
ip tcp synwait-time 10
ip domain name yourdom.de
ip name-server 145.x.x.81
ip name-server 132.x.x.13
no ip bootp server
ip cef
ip ips sdf location flash://attack-drop.sdf
ip ips notify SDEE
ip ips po max-events 100
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
isdn switch-type basic-net3
track 1 rtr 1 reachability
interface Ethernet0
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
no cdp enable
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer pool-member 2
no cdp enable
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 1/32
pppoe-client dial-pool-number 1
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer persistent
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxx
ppp pap sent-username xxxxxxxx password 7 xxxxxxxxxxxxxxxxx
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 2
dialer string 0192076
dialer load-threshold 1 either
dialer-group 2
no cdp enable
ppp chap hostname test
ppp chap password 7 xxxxxxxxxxxxxx
ppp pap sent-username test password 7 xxxxxxxx
ppp multilink
ip local policy route-map ROUTEMAP_1
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 2
ip route 62.x.x.x.255.255.255 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip nat translation timeout 7200
ip nat inside source static udp 192.168.0.10 9077 interface Dialer0 9077
ip nat inside source route-map main interface Dialer0 overload
ip nat inside source route-map secondary interface Dialer1 overload
logging trap debugging
access-list 10 permit 192.168.0.0 0.0.0.255
access-list 102 permit icmp any host 62.x.x.62 echo
access-list 110 permit ip 192.168.0.0 0.0.0.255 any
access-list 111 permit ip 192.168.0.0 0.0.0.255 any
access-list 112 permit ip 192.168.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map main permit 10
match ip address 111
match interface Dialer0
route-map ROUTEMAP_1 permit 1
match ip address 102
set interface Dialer0 Null0
route-map secondary permit 10
match ip address 112
match interface Dialer1
control-plane
rtr 1
type echo protocol ipIcmpEcho 62.x.x.62
timeout 1000
threshold 2
frequency 3
rtr schedule 1 life forever start-time now
vm612
If you are going to have multiple ISPs, why use one primarily and the others on a need be basis, take advantage of all the bandwidth and the redundancy is still built in to your setup. Forget about BGP, it would require a lot of participation from all ISPs and accomplish nothing needed here.
Use equal cost "anything" routes, conversations should be set up to round robin.
r.bhupathi
We can implement HSRP to provie Fault tolerance. NAT can be used in this Scenario. We can look at BGP but slightly complicated process.
Rajendra
