Multiple VLANs and default route to internet
Osirison
My network is connected like this. (I left out the other switches connected to the C3560CX)
[ISP modem]-[Cisco ISR C1111-8P]-[Cisco C3560CX]
The ISR is DHCP server, and running zone based firewall.
The C3560CX is the gateway for the hosts the WAP and other switches, all local and inter vlan traffic should be handled by this switch.
VLAN1     (native, not used)
VLAN10   192.168.10.0 (Hosts)
VLAN20   192.168.20.0 (Guests)
VLAN40   192.168.40.0 (Security Cameras)
VLAN122 192.168.122.0 (Device management)
Question?
Where do I need to set the gateway of last resort to on Switch1?
Right now I do have set it like this
ip route 0.0.0.0 0.0.0.0 192.168.10.1
It works for VLAN10 but it is not correct for the other VLANs...
ISR
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip nat inside
zone-member security COMPUTERS
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip nat inside
zone-member security GUESTS
interface Vlan40
ip address 192.168.40.1 255.255.255.0
ip nat inside
zone-member security CAMERAS
interface Vlan122
ip address 192.168.122.1 255.255.255.0
ip nat inside
zone-member security MANAGEMENT
interface GigabitEthernet0/0/0
description WAN
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip access-group ACL-OUTSIDE-IN in
zone-member security INTERNET
negotiation auto
no cdp enable
interface GigabitEthernet0/1/0
description LAN
switchport mode trunk
ip nat inside source list NAT interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
Switch1
ip routing
interface GigabitEthernet0/10
 description Uplink
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 192.168.10.2 255.255.255.0
interface Vlan20
 ip address 192.168.20.2 255.255.255.0
 ip access-group DenyGuest in
interface Vlan40
 ip address 192.168.40.2 255.255.255.0
 ip access-group 141 in
interface Vlan122
 ip address 192.168.122.2 255.255.255.0
ip http server
It seems to me that we have several mutually contradictory things going on. Especially looking at the way that the ISR is configured with Zone Based Firewall to provide separation between the various vlans/subnets it is problematic to have routing done on the switch. When routing is enabled on the switch then traffic from all vlans/all subnets will be forwarded to the router on one vlan (currently vlan 10 but might be from the management vlan if suggestions in a previous response are followed).
I suggest that we need to clarify what the priorities are and to adjust the config based on that. If the priority is firewalling on the ISR (which is my impression of what the original poster has communicated) then I believe that the switch needs to disable routing and operate as a layer 2 switch. This would need each host connected to the switch to have a default gateway which was the router address for that vlan. This would assure that every packet forwarded to the ISR would arrive on the interface in the appropriate zone. If the priority is to have routing work on the switch then the security policy needs to be altered, zone based firewall removed and some other appropriate security policy implemented (which would be much more on the switch).
Rick
Rick
8 Replies 8
Hello
You have routing applied for all vlans on both the isr and the L3 switch which isn’t required
you only need the inter-vlan routing on the switch - And have an access port in vlan122 for connection between the isr and the switch
A default route on the switch towards the isr vlan122 IP address
Ip route 0.0.0.0 0.0.0.0 vlan122 192.168.122.1
on the isr all you will need is a default route pointing to its wan gif0/0 interface
Ip route 0.0.0.0 0.0.0.0 gig0/0 dhcp
You can remove all the other vlans from the isr and give its lan facing interface an up address in vlan 122
Kind Regards
Paul
Thanks for your reply.
The ISR is also the firewalI.
I want to restrict guest (VLAN20) internet access by only inspecting port 80/443.
For the trusted devices (VLAN10) I want to have more ports to be able to connect to the internet.
For the security cameras (VLAN40) I want only port 123 to be allowed to a single IP of the remote time server.
The ISR has Cisco Umbrella implementation that I would like to try out later, and want to use different DNS policies for guests and trusted devices.
So the ISR has to know what traffic is trusted and what traffic is guest traffic.
The switch forwards vlans (L2 not L3)  to the ISR, there (sub)interfaces handle separate type of clients.
so as Paul already concluded, in your current setup the switch does not need any routing for client traffic.
and as such it don't need a gateway of last resort (or any other IP connectivity) for all vlans, only for the management vlan.
if you want this management vlan accessible from the other vlans this is controlled by the firewall rules of the ISR, not by a gateway of last resort setting.
When I do not set the IP default gateway to 192.168.10.1 then I cannot ping the internet from the switch and also not from the clients connected to the switch.
Rick
Rick
Thank you Rick for your reply!
Its now clear to me that what I configured is not the way it should be.
What I wanted to do is to offload traffic from the security cameras (in VLAN40) from the ISR.
Did this by setting the Switch as the default gateway so all local traffic will be routed by the switch and internet traffic forwarded to the ISR.
But you made it clear that this is not the right setup.
My priority is to have a good firewall at home, I just don't like smart IOT devices having full internet access.
So I have now set the ISR as the default gateway for all sub networks and disabled ip routing on the switches.
Thanks for your input!
I believe that you are on the right path here. I do appreciate the desire to off load from the router the processing for the cameras. But doing this compromises the security approach of the firewall. For zone based firewall to be effective all devices, including cameras, need to use the router as their default gateway. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information.
Rick
Rick
Hello
Basically what your querying I don't see why you cannot negate the users via SVI ACL's on the L3 switch
then what ever is allowed to get through to the ISR will then be subject to the ZBFW policy's, So then inter-lvan routing will be on the L3 switch and ZBFW on the ISR
But if you wish to leave the setup as it is then regarding your OP have default route on the L3 pointing to the mgt vlan122 ip address of the ISR 192.168.122.1
Kind Regards
Paul
