Advise with the choice of border router (ABR)
aleks
Hello.
What I would like to have:
  •     Border is used exclusively for IPv4 routing
  •     Two peers with BGP Full View
  •     Ports 100GB x 2; 10GB x 6; 1GB x 4
  •     The total traffic is about 12Gbps
  •     Redundancy (VSS, HSRP, VRRP, ???)
At the moment, these functions are not badly performed by c7606 with rsp720-3cxl, but we rested in the uplink of 10 G, since traffic in the busiest hours reaches 12Gbps and in case of a fall of one of the peers we will have a problem. There is also no redundancy.
ASR 900X - do not want to consider, because we will never be able to use all the functionality there, even at 5-10% and the price is very high. Not understandable licensing personally for me.
Any ideas?
Alexander
Joseph W. Doherty
Possibly the ASR-1006-X (smallest ASR1K that support two 100G slots) or the Catalyst 9400 series (so you can provision with your different port speeds)..
