Multiple Vlans, sharing printer and file server
Hello All
So, I'm new to Cisco and just wanted to get some help  in setting up Multiple Vlans to print to the same printer and have access to the same fileserver.  Please help, thanks. Please be very basic too.
Seb Rupik
Hi there,
Based on your requirement see the config below. This will create two VLANs and DHCP pools for both. Since you just want communication between the VLANs, there are no ACLs at this stage...
ip routing
vlan 10
vlan 20
int vlan 10
  ip address 192.168.10.254 255.255.255.0
int vlan 20
  ip address 192.168.20.254 255.255.255.0
int gi1/0/1
  desc A_PC
  switchport mode access
  switchport access vlan 10
  spanning-tree portfast
int gi1/0/2
  desc A_SERVER
  switchport access vlan 20
int gi1/0/3
  desc A_PRINTER
ip dhcp pool DHCP_V10
  network 192.168.10.0 255.255.255.0
  domain-name TEST.COM
  dns-server 1.1.1.1
  default-router 192.168.10.254
ip dhcp pool DHCP_V20
  network 192.168.20.0 255.255.255.0
  dns-server 1.1.1.1
  default-router 192.168.20.254
ip dhcp excluded-address 192.168.10.254
ip dhcp excluded-address 192.168.20.254
cheers,
Seb.
Joseph W. Doherty
Assuming your VLANs are support different networks, you'll need a L3 device to route between them.
Se's example is how that might be accomplished on a L3 switch.
What devices, and their feature sets, were you planning to use?
