Port forwarding Cisco 2821
jordanmfarmer
I am wondering how I can setup a PC to port forward with the Cisco 2821 I will need to port forward 3443 on 10.10.10.100, 255.255.255.0
balaji.bandi
If i understand your question correctly
you want to port forward to PC using 2821.
Hopefully your setup as below :
Outside network ----2821-PC ? if this is correct, then follow the setup.
enable NAT on the interface :
use below nat command to foward  :
ip nat inside source static tcp/udp sourceip port destination-ip port  - if it outside to inside use outside.
BB
BB
so I want local ip 10.10.10.2 port 3443 to go outside to the public internet, how exactly would I do that?
int f0/0
desc OUTSIDE
ip nat outside
int f0/1
desc INSIDE
ip nat inside
ip nat inside source static tcp 10.10.10.2 3443 interface fa0/0 3443
