Multiple VPN site to site tunnels
bobby-long
I have an established site to site IPSEC tunnel from location A to B. I need to establish a remote site C from site A simultaneously. The equipment is two 2811 routers. Can I create two tunnels on one serial interface? I have created one crypto map and two policies for that crypto map. Both sessions show up, but only the original is session is active. I have used SDM to test the second tunnel, and it passes, but still does not function. Any help would be appreciated.
Bobby
15 Replies 15
iqbalkhan
HI
You can do by sub two interface in serial interface and bind two sub interface.
thanks
Biplob
HI
here is under example for one point two another two point for VPN.
If center point dc and other two point is ho and fex
one want interface fastethernet1/0 then configer in dc.if you have serial interface then subinterface like this.
crypto isakmp policy 110
encr 3des
hash md5
group 2
crypto ipsec transform-set dc-all ah-md5-hmac esp-3des esp-md5-hmac
crypto map dc-ho 10 ipsec-isakmp
set peer 192.168.5.2
set transform-set dc-all
match address 100
crypto map dc-fex 10 ipsec-isakmp
set peer 192.168.5.22
match address 105
interface FastEthernet1/0.1
encapsulation dot1Q 100
ip address 192.168.5.1 255.255.255.252
crypto map dc-ho
interface FastEthernet1/0.6
encapsulation dot1Q 105
ip address 192.168.5.21 255.255.255.252
crypto map dc-fex
access-list 100 permit ip host 192.168.5.1 host 192.168.5.2
access-list 105 permit ip host 192.168.5.21 host 192.168.5.22
--------------------- for remote branch example======
encr 3des
hash md5
group 2
crypto ipsec transform-set dbbl_ho ah-md5-hmac esp-3des esp-md5-hmac
crypto map ho-dc 10 ipsec-isakmp
set peer 192.168.5.1
set transform-set dbbl_ho
match address 100
interface Loopback0
ip address 10.90.255.1 255.255.255.0
interface Ethernet0/0
ip address 10.65.50.1 255.255.255.0
half-duplex
interface FastEthernet0/0
no ip address
speed auto
interface FastEthernet0/0.2
ip address 192.168.5.2 255.255.255.252
crypto map ho-dc
I think this example help you
Biplob
My subinterface is a serial0/0/0.1 that is my ISP endpoint on a frame connection. Can I make another subinterface with an IP address that is not global(private) and have it work, or do I have to contact my ISP and get a second endpoint with a global address? The config makes sense, but I only have one public IP for the interface.
Thanks again for your help,
Bobby
attrgautam
Level 5
Level 5
Ofcourse it is possible. My guess is that you are using the same access-lists for both locations. It will be helpful if u can show the relevent configuration.
It seemed logical to me, but since I can't get it to work...I had some question. Maybe about myself ;) Here is the config:
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp policy 20
hash md5
crypto isakmp key ??????? address 109.155.1.150 255.255.255.252
crypto isakmp key ??????? address 109.207.9.114 255.255.255.252
crypto ipsec transform-set strong esp-des esp-md5-hmac
crypto ipsec df-bit clear
crypto map myset 10 ipsec-isakmp
description site A to Site B Tunnel
set peer 109.155.1.150
set transform-set strong
match address 101
crypto map myset 20 ipsec-isakmp
set peer 109.207.9.114
match address 103
interface Loopback0
ip address 192.168.71.4 255.255.255.0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 171.66.104.193 255.255.255.192
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.20.92.6 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
description USLEC frame circuit
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
description frame
ip address 45.46.60.218 255.255.255.252
ip access-group 135 in
ip nat outside
frame-relay interface-dlci 284
crypto map myset
access-list 101 permit ip 172.20.92.0 0.0.0.255 172.20.93.0 0.0.0.255
access-list 101 permit ip 192.168.71.0 0.0.0.255 172.20.93.0 0.0.0.255
access-list 101 permit ip host 172.31.92.2 172.20.93.0 0.0.0.255
access-list 101 permit ip host 71.16.104.205 172.20.93.0 0.0.0.255
access-list 101 permit ip host 172.31.91.156 172.20.93.0 0.0.0.255
access-list 101 permit ip host 172.31.92.2 host 172.20.93.14
access-list 103 permit ip 192.168.71.0 0.0.0.255 172.20.94.0 0.0.0.255
access-list 103 permit ip 172.20.92.0 0.0.0.255 172.20.94.0 0.0.0.255
Ok will need information about the NAT acl also if any. IF yes, explicitly deny the IPSec traffic in the NAT ACL. What exactly does sh crypto isakmp sa and sh crypto ipsec sa give you ?
There is no NAT acl on this particular router. The sh crypto isakmp sa and the sh crypto ipsec sa, both show the original tunnel, but make no mention of the second tunnel that I am trying to build. What I do find strange is that if I do a sh crypto map, the second tunnel lists the peer on the remote end (at the top of the results), but under "current peer" the address is blank.
Thanks for your help on this,
Bobby
Are the configs at either end match ? Any chance of a peek at the remote end config. Atleast ISAKMP should come up. What exactly is happening in the NAT ?
here is the relevent config from the remote end of the second tunnel:
crypto isakmp policy 40
hash md5
crypto isakmp key ???????? address 45.x.x.218
crypto map wpoaub 40 ipsec-isakmp
set peer 45.x.x.218
match address 104
call rsvp-sync
ip address 172.x.x.x.255.255.0
ip nat inside
full-duplex
no cdp enable
interface Serial0/0
ip address 109.207.x.x.x.255.252
ip nat outside
fair-queue
crypto map wpoaub
interface Ethernet0/1
no ip address
ip nat inside
half-duplex
no cdp enable
ip nat pool Tests 1.1.1.1 1.1.1.1 netmask 255.255.255.248
ip nat inside source route-map Internet pool Test overload
ip classless
ip route 0.0.0.0 0.x.x.x.207.9.113
ip route 172.20.92.0 255.255.255.0 Serial0/0
ip route 192.168.61.0 255.255.255.0 Serial0/0
no ip http server
ip http authentication local
logging history alerts
logging facility syslog
logging source-interface Serial0/0
access-list 2 permit 172.20.94.0 0.0.0.255
access-list 101 deny ip 172.20.94.0 0.0.0.255 172.20.92.0 0.0.0.255
access-list 101 deny ip 172.20.94.0 0.0.0.255 192.168.71.0 0.0.0.255
access-list 101 permit ip 172.20.94.0 0.0.0.255 any
access-list 104 permit ip 172.20.94.0 0.0.0.255 192.168.71.0 0.0.0.255
access-list 104 permit ip 172.20.94.0 0.0.0.255 172.20.92.0 0.0.0.255
route-map Internet permit 40
match ip address 101
linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps syslog
ntp clock-period 17208671
ntp peer 208.x.x.241
ntp server 192.5.41.209
end
I can see traffic traveling through the 103 access-list on the local end so I know it atleast is directed toward the tunnel. I do not see hits on the access-list at the remote end though.
Best regards,
Bobby
Please try with just ACL 103 in crypto map and confirm whether you can able to create ISAKMP and IPSec SAs or not for this particular peer.
And although it is bit silly question, did you try to initiate any traffic as permitted in ACL 103 as the ISAKMP negotiation happens only after matching the traffic in the ACL.
Thank you,
Regards...
-Ashok.
With best regards...
Ashok
No sa shows up for either isakmp or ipsec. Question- do you have to "reapply" a crypto map to an interface after you modify it?
Respectfully,
Bobby
Any chance of a debug at the remote end just to see if there is any isakmp negotiation happening at all ? I was wondering if there is a firewall on the path which totally blocks out all communication. There is an access-list 135 on the hub. Does it have the necessary permissions for the remote peer ? I think it is a good idea to remove the crypto map and apply it again at the hub.
The access-list 135 is not applied at this point because there is nothing attached by a laptop. I figured I would get this working and then lock it down. I will reapply the map and see what happens.
Thanks!
Bobby
Here is the debug from the central router for an attempted connection to the remote:
Apr 18 13:51:24.488: ISAKMP: received ke message (1/1)
Apr 18 13:51:24.488: ISAKMP:(0:0:N/A:0): SA request profile is (NULL)
Apr 18 13:51:24.488: ISAKMP: Created a peer struct for 2.2.2.2, peer port 500
Apr 18 13:51:24.488: ISAKMP: Locking peer struct 0x43E75690, IKE refcount 1 for isakmp_initiator
Apr 18 13:51:24.488: ISAKMP: local port 500, remote port 500
Apr 18 13:51:24.488: ISAKMP: set new node 0 to QM_IDLE
Apr 18 13:51:24.488: insert sa successfully sa = 43EB0EE0
Apr 18 13:51:24.488: ISAKMP:(0:0:N/A:0):Can not start Aggressive mode, trying Main mode.
Apr 18 13:51:24.488: ISAKMP: Looking for a matching key for 2.2.2.2 in default : success
Apr 18 13:51:24.488: ISAKMP:(0:0:N/A:0):found peer pre-shared key matching 2.2.2.2
Apr 18 13:51:24.488: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-03 ID
Apr 18 13:51:24.488: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-02 ID
Apr 18 13:51:24.488: ISAKMP:(0:0:N/A:0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
Apr 18 13:51:24.488: ISAKMP:(0:0:N/A:0):Old State = IKE_READY New State = IKE_I_MM1
Apr 18 13:51:24.488: ISAKMP:(0:0:N/A:0): beginning Main Mode exchange
Apr 18 13:51:24.488: ISAKMP:(0:0:N/A:0): sending packet to 2.2.2.2 my_port 500 peer_port 500 (I) MM_NO_STATE
Apr 18 13:52:09.487: ISAKMP: quick mode timer expired.
Apr 18 13:52:09.487: ISAKMP:(0:0:N/A:0):src 1.1.1.1 dst 2.2.2.2, SA is not authenticated
Apr 18 13:52:09.487: ISAKMP:(0:0:N/A:0):peer does not do paranoid keepalives.
Apr 18 13:52:09.487: ISAKMP:(0:0:N/A:0):deleting SA reason "QM_TIMER expired" state (I) MM_NO_STATE (peer 2.2.2.2)
Apr 18 13:52:09.487: ISAKMP: Unlocking IKE struct 0x43E75690 for isadb_mark_sa_deleted(), count 0
Apr 18 13:52:09.487: ISAKMP: Deleting peer node by peer_reap for 2.2.2.2: 43E75690
Apr 18 13:52:09.487: ISAKMP:(0:0:N/A:0):deleting node 1524471441 error FALSE reason "IKE deleted"
Apr 18 13:52:09.487: ISAKMP:(0:0:N/A:0):deleting node -714872047 error FALSE reason "IKE deleted"
Apr 18 13:52:09.487: ISAKMP:(0:0:N/A:0):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
Apr 18 13:52:09.487: ISAKMP:(0:0:N/A:0):Old State = IKE_I_MM1 New State = IKE_DEST_SA
