MULTIPOINT BGP REDISTRIBUTION INTO OSPF AREA O FAILOVER ISSUES
.245, .246 AND .247 ARE OSPF NEIGHBOURS IN AREA 0 AND THEY EXCHANGE ROUTES.
.5, .10 AND .1 CAN SEE EACH OTHER LOCALLY THROUGH VXLAN SWITCH. THAT SWITCH REPRESENTS VXLAN CONFIG AND ITS OUT OF THE SCOPE.
ALL THE SONICWALLS CAN REACH EACH OTHER AND THE 1.1.1.0 NETWORK AND THEY ARE ADVERTISING THIS RANGE TO THE JUNIPER D ROUTER B AND ROUTER C
ROUTER B, C AND JUNIPER D ARE REDISTRIBUTING THIS RANGE INTO OSPF SUCCESSFULLY
PRIMARY ROUTER TO BE USED TO REACH 1.1.1.0 NETWORK IS ROUTER B WHICH IS GOOD
IF I TURN OFF THAT ROUTER THE ROUTE IS FAILING OVER SUCCESSFULLY TO ROUTER C
THE PROBLEM COMES WHEN I WANT TO FAIL BACK WHEN ROUTER B COMES BACK ONLINE
ITS NOT FAILING BACK AND ITS A HUGE PROBLEM FOR ME
THE PROBLEM IS IT SEEMS THESE METRICS DO NOT WORK PROPERLY, SOMETIMES I SEE A HIGHER METRIC ROUTE FOR A NETWORK BEING PREFFERED OVER A LOWER METRIC, ALSO EVEN IF THE LOWER METRIC ROUTE IS PREFERRED WHEN THAT ROUTE IS REMOVED AND IT FAILS OVER TO A HIGHER METRIC ROUTE, ITS NOT FAILING BACK TO THE LOWER METRIC ROUTE WHEN ITS REINTRODUCED IN THE NETWORK
Sorry can you more elaborate what exactly issue here?
MHM
I HAVE REEDITED THE MESSAGE
