Unable to Access Web Server - Whats Wrong with this Configuration
mfdarvesh
ASA working in IPSec, I am able to access HQ from UNIT No problem. Internet is only allowed on specific IPs which are outside DHCP Scope. When I assign IP for internet, now Internet is working, HQ Network is accessible, but S_EXT (webserver - 10.10.10.111) don't work. Unable to understand why it is working when internet is OFF. Here is configuration - What's wrong pl
ASA Version 9.1(1)
interface GigabitEthernet0/0
description ****WAN-INTERFACE****
nameif outside
security-level 0
ip address 203.x.x.x 255.255.255.252
interface GigabitEthernet0/1
description ****LAN-INTERFACE****
nameif inside
security-level 100
ip address 192.168.135.1 255.255.255.0
ftp mode passive
object network OBJ_ANY
subnet 0.0.0.0 0.0.0.0
object network S_INTERNET
range 192.168.135.230 192.168.135.240
object network S_UNIT
subnet 192.168.135.0 255.255.255.0
object network HQ
subnet 192.168.100.0 255.255.255.0
object network S_EXT
host 10.10.10.111
access-list 100 extended permit ip object S_UNIT object HQ
access-list 100 extended permit ip object S_UNIT object S_EXT
access-list OUTSIDE extended permit icmp any any echo
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static S_UNIT S_UNIT destination static HQ HQ
nat (inside,outside) source static S_EXT S_EXT destination static HQ HQ
nat (inside,outside) dynamic interface
access-group OUTSIDE in interface outside
route outside 0.0.0.0 0.0.0.0 203.x.x.x 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
no snmp-server location
no snmp-server contact
crypto ipsec ikev1 transform-set MYSET esp-3des esp-md5-hmac
crypto ipsec security-association pmtu-aging infinite
crypto map VPNMAP 20 match address 100
crypto map VPNMAP 20 set peer x.x.x.x
crypto map VPNMAP 20 set ikev1 transform-set MYSET
crypto map VPNMAP interface outside
crypto ca trustpool policy
crypto ikev1 enable outside
crypto ikev1 policy 1
authentication pre-share
encryption
hash md5
group 2
lifetime 86400
telnet timeout 5
dhcpd dns 8.8.8.8
dhcpd address 192.168.135.50-192.168.135.200 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
tunnel-group x.x.x.x type ipsec-l2l
tunnel-group x.x.x.x ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
class-map default
policy-map type inspect dns migrated_dns_map_1
parameters
: end
20 Replies 20
access-list 100 extended permit ip object S_UNIT object S_EXT <<- this line of crypto ACL is confuse me' I think it wrong
Compare to no-NAT you use
MHM
mfdarvesh
Thank you - what should I do ? Need to allow my UNIT to access this webserver located on HQ Subnet (10.10.10.111 is behind that subnet) and it is Tunnel traffic so also need to exclude it from NAT.
If the config you share is not for HQ then you need
access-list 100 extended permit ip object S_EXT object HQ
Again thank you - config is of UNIT not HQ, S_EXT (10.10.10.111) is a webserver which is accessible through HQ subnet (not placed in HQ). This config works good and server is accessible in UNIT office, when internet is not working. Once internet is available in UNIT on same network this server is inaccessible, will try update access-list and will update pl
Changed access-list to above and now S_EXT is inaccessible from UNIT even without Internet. So, it is not working.
Hello
Can you share a topology diagram of this, As it will assist on understanding this issue and providing a solution
Kind Regards
Paul
Yes please @mfdarvesh  share topolgy
MHM
mfdarvesh
Forgive me on by bad diagram pl
Hello
So the ASA and this configuration is from UNIT , Which shows it has a Lan interface in 192.168.135.x and a wan interface, which suggest reachability to HQ is over via the internet and HQ is NATing for its internal web servers?
What i dont understand is your comment that HQ web server ( 10.10.10.111 S_EXT)  IS reachable when internet is turned off at UNIT
Kind Regards
Paul
@paul driver wrote:
Hello
UNIT and HQ and on IPSec tunnel and it is working. Internet is not available in UNIT (only specific IPs 192.168.100.230 has Internet). UNIT is able to access S_EXT Server when Internet is not working. When I assign UNIT PC IP Address 192.168.100.230 (Internet IP), now S_EXT server is not accessible, rest of HQ tunnel is working good, I am unable to understand, why it is creating problem with Internet enables IP in UNIT
in UNIT do you add route toward HQ for S_EXT?
MHM
MHM
NO - as this server (S_EXT) is part of HQ Subnet and through IPSec tunnel, it is working but only when Internet is not enabled in UNIT Subnet
All traffic from Br to HQ is through IPSec tunnel, servers directly placed in HQ are accessible, the only server, which is not placed in HQ and accessible through HQ subnet is creating problem.
