mutual redistribution between EIGRP and BGP
saimbt
I have to do a mutual redistribution between EIGRP and BGP, can anyone help me?
-Sai.
Pravin Phadte
Level 5
Level 5
Suppose the bgp is running on a router somewhere else in as 1, and that the bgp routes are inhected into IP eigrp routing process 1. You must use filteres to ensure that the proper routes are advertised.
The example configuration for the router use of access filteres and a distribution list to fileter routes advertised to bgp neighbours.Also comfiguration commands for redistribution between bgp and Ip eigrp.
lets consider R1-R2-R3 connetd and R1 running BGP and R3 running EIGRP
Config R2
router bgp 1
network 131.108.0.0
neighbour 192.5.10.1 remote-as 2
neighbour 192.5.10.15 remote-as 1
neighbour 192.5.10.24 remote-as 3
redistribute eigrp 1
distribute-list 1 out eigrp 1
all networks that should be advertise from router are controlled with access list
access-list 1 permit 131.108.0.0
access-list 1 ermit 150.136.0.0
access-list 1 permit 128.125.0.0
router eigrp 1
network 131.108.0.0
network 192.5.10.0
redistribute bgp 1
Below is a link for more refrence.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009487e.shtml
Hope this helps,
regards,
Pravin
Hey Pravin, I guess while redistributing BGP into EIGRP, I need to define bandwidth, delay, reliability, load, and MTU.
-Sai.
Config R2
router bgp 1
network 131.108.0.0
redistribute eigrp 1 metric 10000 100 255 1 1500
router eigrp 1
network 131.108.0.0
network 192.5.10.0
redistribute bgp 1
bandwidth: In units of kilobits per second; 10000 for Ethernet
delay:In units of tens of microseconds; for Ethernet it is100 x 10 microseconds = 1 ms
reliability:255 for 100 percent reliability
load:Effective load on the link expressed as a number from 0 to 255 (255 is 100 percent loading)
MTU:Minimum MTU of the path; usually equals that for the Ethernet interface, which is 1500 bytes
Also the link provided below will help.
Hope this helps.
Pravin
