My 877W Router stops responding if not active in some period of time, please help
zxspectrum128kb
Hello everyone!
I ave this kind of problem on my 877W router:
The router is connected to ISP throuth its FE0 interface because I have a cable internet:
interface FastEthernet0
end
interface Vlan1
no ip address
no ip redirects
bridge-group 1
bridge-group 1 spanning-disabled
end
interface BVI1
mac-address ####.####.####
ip address dhcp
ip directed-broadcast
ip flow ingress
ip nat outside
ip virtual-reassembly
zone-member security OUTSIDE
end
I have done this way because router doesn't have a routable switchport and plus I have to use MAC address to get ISP's IP address.
ok, internal network is connected through its FE1 interface and IP addres is set on VLAN 2 interface.
interface Vlan2
ip address 192.168.2.1 255.255.255.0
no ip redirects
ip flow ingress
ip nat inside
zone-member security INSIDE
end
There's nothing else connected to the router.
Now problem is that the router stops responding from outside world after some inactivity period. eg if I shutdown computers inside internal (VLAN 2) network, then in some period of time the router stops accepting anything on WAN interface.
As soon as I turn on something in VLAN 2 network, it goes back as normal. Do I need to play with keepalive command, and if yes, where?
I need your help!
thanks
Hello.
How do you check that router is not responding?
My guess:
You might be trying to connect to some IP-address that is NATed into VLAN2 address.
After VLAN2 goes down, you can't connect to inside interface.
Nope, I'm trying to connect to the router itself, of course I can't reach anything inside VLAN 2 interface when WAN is down.
Hello.
What IP-address are you using to connect to the router?
What is your address during the test?
Do you have any NAT translations configured for th IP-address?
What does show log say?
I'm trying to connect using WAN interface IP address, from outside, there's no ping. As soon as something is turned on inside network it pings again.
of course I have NAT configured. I think that the FE0 or BVI interface goes down after inactivity period and goes up if NAT activates from inside network.
I think I need to log in to the router by console and check exactly which interface going down.
