My problem is I can ping from 192.168.167.x to 192.168.169.x any Pc IP but I am not able to ping 192.168.167.x PC
Sir,
This is my complete configuration
My problem is I can ping from 192.168.167.x to 192.168.169.x any PV IP but I am not able to ping 192.168.167.x PC
Site 1
User Access Verification
Password:
rak2electro#sh conf
Using 1071 out of 196600 bytes
version 12.4
hostname rak2electro
boot-start-marker
boot-end-marker
enable secret 5 $1$7bRu$v7z43tOJ984HwI/IT2YVs/
enable password cisco1
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
username admin privilege 15 secret 5 $1$vNDV$3r7G2IVK11qH3AV8ZZPlL1
interface FastEthernet0/0
ip address 192.168.167.101 255.255.255.0
ip nat inside
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
ip address 192.168.166.202 255.255.255.0
ip nat outside
duplex auto
speed auto
router rip
version 2
redistribute connected
network 192.168.166.0
network 192.168.167.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.166.205
ip http server
access-list 100 permit ip any any
control-plane
line con 0
password cisco
login
line aux 0
line vty 0 4
privilege level 15
password cisco
login
end
rak2electro#
Site 2
elec2rak#sh conf
Using 923 out of 196600 bytes
version 12.4
hostname elec2rak
boot-start-marker
boot-end-marker
enable secret 5 $1$Il0J$MHk9XlAzWOSdgb/YqFKCt/
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip address 192.168.169.252 255.255.255.0
ip nat inside
speed auto
full-duplex
no mop enabled
ip address 192.168.166.205 255.255.255.0
ip nat outside
duplex auto
speed auto
router rip
version 2
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.166.202
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
end
elec2rak#
9 Replies 9
Leo Laohoo
Firewall?
No there is no firewall. I cant ping from 192.168.169.x to 192.168.167.x but from both side i can use remote desktop(MSTSC)
Hi Naresh,
Possible options for this scenario:
- Remove the NAT statements from the interface on both the routers as NAT is not being used
- Disable and enable CEF using the commands "no ip cef" and "ip cef"
- Reload the router and test again
- If all above fails, then run the icmp debugs on the routers "debug ip icmp" to know more as the config looks okay on the routers
Hope it helps
Neeraj
Thanks Niraj,
I removed nat from fa0/0 and fa0/1 from both router and also removed cef. no success.
debug ip icmp shows ICMP PACKET DEBUGGING IS ON
to get sure I understand your problem correctly: you can ping from 192.168.167.x to 192.168.169.x but not the other way?
are you doing thse pings from host to host? in that case the debug ip icmp won't help you as all debugs are for router generated traffic or traffic destined to the router not traffic forwarded by the router and you won't even change this behaviour for icmp debugging by disabling CEF( which would work for debug ip packet).
If these are windows hosts you should try with the software firewall disabled or change the network location  to home for Windows 7.
Regards.
Alain
Router 1
Lan : 192.168.167.101
Wan: 192.168.166.102
Pc1 : 192.168.167.202
OS :Windows 7
Router 2
Lan: 192.168.169.252
Wan:192.168.166.205
Pc2: 192.168.169.10
OS: Xp Prof
I can ping from pc1 to pc2 but not from pc2 to pc1
regards
Did you try by replacing 'network 192.168.167.0' with 'network 192.168.169.0' under 'rip' for router 'elec2rak'?
Thx
MS
Yes did that. replacing network 192.168.167.0 with 192.168.169.0
My Site Connectivity is ..
Site A:
pc: 192.168.169.202
3com Wireless  Bridge1 : 192.168.169.254
3Com Wireless Bridge2: 192.168.169.174
Router1
Lan : 192.168.169.252
Wan: 192.168.166.205
Router2
Wan: 192.168.166.202
Lan 192.168.167.102
Pc: 192.168.167.202
regards
you should definitely check the Windows 7 network location and set it as home( private) to permit the icmp echo-request from the XP PC, it is definitely not a routing problem and you can prove it by pinging router interfaces in one subnet from the other router  sourcing the ping from other subnet.
Regards.
Alain
