Mystery Router Reboot
One of our clients recently experienced their CPE Router rebooting for some reason. We have checked and there does not seems to have been any deliberate action from anyone on site or any power issues.
The logs are as follows:
*May 22 09:41:43.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*May 22 09:41:43.319: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*May 22 09:41:43.319: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*May 22 09:41:44.687: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
*May 22 09:41:44.691: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*May 22 09:41:44 GMT: %SYS-6-CLOCKUPDATE: System clock has been updated from 09:41:44 UTC Tue May 22 2012 to 09:41:44 GMT Tue May 22 2012, configured from console by console.
*May 22 10:41:44 BST: %SYS-6-CLOCKUPDATE: System clock has been updated from 09:41:44 GMT Tue May 22 2012 to 10:41:44 BST Tue May 22 2012, configured from console by console.
*May 22 10:41:56 BST: %SYS-5-CONFIG_I: Configured from memory by console
*May 22 10:41:57 BST: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*May 22 10:41:57 BST: %SYS-5-RESTART: System restarted --
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 28-Apr-09 13:10 by XXXXXXXXXXX
*May 22 10:41:57 BST: %SNMP-5-COLDSTART: SNMP agent on host XXXXXXXXXXX is undergoing a cold start
*May 22 10:41:57 BST: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host XXXXXXXXX port 514 started - CLI initiated
*May 22 10:41:57 BST: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host XXXXXXXXXX port 514 started - CLI initiated
*May 22 10:41:58 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
*May 22 10:42:02 BST: %BGP-5-ADJCHANGE: neighbor XXXXXXXXXXXXX Up
*May 22 10:42:31 BST: %LINK-3-UPDOWN: Interface ATM0/0/0, changed state to up
*May 22 10:42:32 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0/0, changed state to up
*May 22 10:42:41 BST: %LINK-3-UPDOWN: Interface ATM0/0/0, changed state to down
*May 22 10:42:42 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0/0, changed state to down
*May 22 10:43:11 BST: %LINK-3-UPDOWN: Interface ATM0/0/0, changed state to up
*May 22 10:43:12 BST: %DIALER-6-BIND: Interface Vi2 bound to profile Di0
*May 22 10:43:12 BST: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*May 22 10:43:12 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0/0, changed state to up
.May 22 10:30:25 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
Can anyone advise if these logs indicate what the likely cuase of the reboot was, or where I might track down what caused the reboot?
Network Engineer
CCIE SP #69245
Here's the reason.  The router reboot due to a loss of power.
10 Replies 10
Leo Laohoo
Can you post the output to the following commands:
1.  sh version
2.  dir flash:
Router#show version
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Router uptime is 1 day, 12 hours, 59 minutes
System restarted at 10:28:38 BST Tue May 22 2012
System image file is "flash:c2800nm-spservicesk9-mz.124-15.T9.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FCZ132570ZM
2 Gigabit Ethernet interfaces
1 ATM interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Router#dir flash:
Directory of flash:/
    1  -rw-    44446708  Mar 31 2010 11:15:28 +01:00  c2800nm-spservicesk9-mz.124-15.T9.bin
    2  -rw-        2751  Jun 18 2009 06:18:54 +01:00  sdmconfig-28xx.cfg
    3  -rw-      931840  Jun 18 2009 06:19:10 +01:00  es.tar
    4  -rw-     1505280  Jun 18 2009 06:19:26 +01:00  common.tar
    5  -rw-        1038  Jun 18 2009 06:19:38 +01:00  home.shtml
    6  -rw-      112640  Jun 18 2009 06:19:52 +01:00  home.tar
    7  -rw-     1697952  Jun 18 2009 06:20:12 +01:00  securedesktop-ios-3.1.1.45-k9.pkg
    8  -rw-      415956  Jun 18 2009 06:20:30 +01:00  sslclient-win-1.1.4.176.pkg
64016384 bytes total (14884864 bytes free)
Network Engineer
CCIE SP #69245
*Aug 12 17:14:07: %BFD-6-BFD_IF_CONFIGURE: BFD-SYSLOG: bfd config apply, idb:GigabitEthernet0/0/0.2
*Aug 12 17:14:09: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 32.75.230.150 port 0 CLI Request Triggered
*Aug 12 17:14:09: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 32.75.230.25 port 0 CLI Request Triggered
*Aug 12 17:14:10: %LINK-5-CHANGED: Interface GigabitEthernet0/0/2, changed state to administratively down
*Aug 12 17:14:10: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Aug 12 17:14:10: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 12 17:14:10: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Aug 12 17:14:10: %SPA_OIR-6-OFFLINECARD: SPA (ISR4351-3x1GE) offline in subslot 0/0
*Aug 12 17:14:10: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Aug 12 17:14:10: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Aug 12 17:14:10: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Aug 12 17:14:10: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Aug 12 17:14:10: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Aug 12 17:14:10: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Aug 12 17:14:10: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 2
*Aug 12 17:14:10: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 2
*Aug 12 17:14:10: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Aug 12 17:14:12: %SYS-5-RESTART: System restarted --
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Sat 22-Jul-17 05:55 by mcpre
*Aug 12 17:14:12: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Aug 12 17:14:12: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 32.75.230.150 port 514 started - CLI initiated
*Aug 12 17:14:12: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 32.75.230.25 port 514 started - CLI initiated
*Aug 12 17:14:13: %SNMP-5-COLDSTART: SNMP agent on host HKLMHFHON0020R is undergoing a cold start
*Aug 12 17:14:15: %TRANSCEIVER-6-INSERTED:  SIP2: iomd:  transceiver module inserted in Gigabitethernet0/0/0
reason : Reload command ... no one has done manually (reload)
what platform/model is this on ?
Thank you
Network Engineer
CCIE SP #69245
You're very welcome.  And thank you for the ratings.
System restarted at 17:34:35 UAE Sun Apr 10 2022
what device is this on, which IOS are you running ?
khan manzoom
Why we are getting this error when we execute this command. please explain in brief
