N7K-C7010 NX-OS 5.2.1 with N7K-M108X2-12L Unable to Run Multicast Routing
emcueto08
Hi Guys,
Need your help on this.
I have an N7N-C7010 running NX-OS 5.2.1 with N7K-SUP1 and N7K-M108X2-12L.
I was unable to run Multicast Routing (Inter-VLAN Multicast)
Here are the configurations:
interface Vlan131
  ip address 10.240.141.2/24
  ip ospf passive-interface
  ip router ospf 10 area 0.0.0.0
  ip pim sparse-mode
  ip igmp version 2
  hsrp 131
    preempt
    priority 105
    ip 10.240.141.1
  ip dhcp relay address 10.240.131.13
  no shutdown
  description IPTV
interface Vlan14
  ip address 10.240.144.2/23
  ip pim sparse-mode
  ip igmp version 2
  hsrp 14
    preempt
    priority 105
    ip 10.240.144.1
  ip dhcp relay address 10.240.2.100
  no shutdown
  description USERS
Router# sho ip igmp groups
IGMP Connected Group Membership for VRF "default" - 3 total entries
Type: S - Static, D - Dynamic, L - Local, T - SSM Translated
Group Address      Type Interface           Uptime    Expires   Last Reporter
224.0.1.60         D    Vlan14              04:55:48  00:02:37  10.240.144.60
239.255.255.246    D    Vlan14              04:55:44  00:02:41  10.240.144.32
239.255.255.250    D    Vlan14              04:55:52  00:02:33  10.240.144.60
Router#
Source is connected on VLAN131 while the client on VLAN14.
Hope someone can reply today. Need your feedbacks asap as I'm on-site right now.
Eugene
5 Replies 5
Jon Marshall
Eugene
Not familiar with Nexus switches so these questions might not be applicable but  -
1) have you configured an RP ? If not you can either -
a) configure the Nexus to be an RP
or
b) configure "ip pim sparse-dense-mode" under the vlan interfaces (if supported)
2) have you checked that the TTL of the packets is greater than 1 (it needs to be to be routed across the vlan interfaces). The TTL settings would be on the actual source ie. usually set in the application itself.
Jon
Hi Jon,
For now its just inter-VLAN routing and I don't think we need RP right away.
There's no option if sparse-dense on Nexus.
As requested, please see output below:
Router# sho ip mroute summ
IP Multicast Routing Table for VRF "default"
Total number of routes: 32
Total number of (*,G) routes: 3
Total number of (S,G) routes: 28
Total number of (*,G-prefix) routes: 1
Group count: 9, rough average sources per group: 3.1
Group: 224.0.1.60/32, Source count: 1
Source          packets      bytes           aps   pps       bit-rate     oifs
(*,G)           43           3096            72    0         0.000   bps  1
10.240.144.51   36           2732            75    0         10.133  bps  1
Group: 232.0.0.0/8, Source count: 0
(*,G)           0            0               0     0         0.000   bps  0
Group: 239.0.1.2/32, Source count: 1
192.168.10.100  1            1344            1344  0         0.000   bps  0
Group: 239.0.1.3/32, Source count: 1
Group: 239.0.1.4/32, Source count: 1
Group: 239.0.1.5/32, Source count: 1
Group: 239.0.1.6/32, Source count: 1
Group: 239.0.1.8/32, Source count: 1
Group: 239.255.255.246/32, Source count: 0
(*,G)           0            0               0     0         0.000   bps  1
Group: 239.255.255.250/32, Source count: 21
(*,G)           21           6661            317   0         0.000   bps  2
10.240.141.14   108          42812           396   0         0.000   bps  2
10.240.141.16   93           15341           164   0         0.000   bps  2
10.240.144.17   395          202281          512   0         0.000   bps  2
10.240.144.18   36           18005           500   0         0.000   bps  2
10.240.144.19   8            1316            164   0         0.000   bps  2
10.240.144.24   6            986             164   0         0.000   bps  2
10.240.144.30   92           15176           164   0         0.000   bps  2
10.240.144.31   11           1811            164   0         0.000   bps  2
10.240.144.32   144          48676           338   0         0.000   bps  2
10.240.144.33   124          62015           500   0         0.000   bps  2
10.240.144.39   6            986             164   0         0.000   bps  2
10.240.144.46   6            986             164   0         0.000   bps  2
10.240.144.49   9            1481            164   0         0.000   bps  2
10.240.144.53   56           9236            164   0         0.000   bps  2
10.240.144.58   120          60014           500   0         0.000   bps  2
10.240.144.59   48           7480            155   0         0.000   bps  2
10.240.144.73   9            1481            164   0         0.000   bps  2
10.240.144.81   103          35630           345   0         0.000   bps  2
10.240.144.82   347          81029           233   0         0.000   bps  2
10.240.144.85   4            656             164   0         0.000   bps  2
10.240.144.108  6            6832            1138  0         0.000   bps  2
Router#
Eugene
Eugene
Is it because it is all on one switch you say you do not need an RP ?
My understanding of PIM sparse mode was that an RP was required and not optional.
Could you try just configuring the Nexus as the RP and see what happens ?
Jon
Jon Marshall
Eugene
Can you also post output of "sh ip mroute "
Jon
Hi Jon,
Right now were doing the test on multicast address 239.0.1.2 between VLANs 131(server) and 14(listener).
Eugene
