07-08-2020 11:58 PM
Has anyone come across issues with the naming of match statements in route-maps containing '>' or know of any documentation on what is allowed. I am trying to apply the following:
ip prefix-list PL_OSPF98>>BGP65001_ME50 seq 5 permit 10.10.10.0/24
route-map RM_OSPF98>>BGP65001 permit 10
match ip address prefix-list PL_OSPF98>>BGP65001_ME50
set metric 50
It works fine up to the match line and errors with:
DC1-N9K-LEAF01(config-route-map)# match ip address prefix-list PL_OSPF98>>BGP65001_ME50
Error: CLI DN creation failed substituting values. Path sys/rpm/rtmap-[RM_OSPF98BGP65001]/ent-10/mrtdst/rsrtDstAtt-[sys/rpm/pfxlistv4-[PL_OSPF98>>BGP65001_ME50]]
If I remove the '>' from the line it works so seems to not like them. Does anyone know what this error means or if is a bug? This happens on a virtual device in EVE-NG on version nxos.9.2.4.bin, however on sbx-nxos-mgmt.cisco.com which is on nxos.9.3.3.bin it doesnt.
Solved! Go to Solution.
08-24-2020 01:44 AM
Looks to be the version of code. I built a new N9K with 9.3.5 (nexus9300v.9.3.5.qcow2) and no longer have the problem.
07-09-2020 01:25 AM - edited 07-09-2020 01:29 AM
Hello @sjhloco ,
I have never tried to use a non alphanumeric character in the name of a prefix-list or a route-map.
I use TO or INTO instead of ">>" .
This can be considered a minor issue.
I would suggest to change your naming convention.
Edit:
I have realized I use "-" or "_" in names with no issues all the other chars I use are alphanumeric.
In C++ >> is an operator for example to read from input or ouput when the route-map name is passed at lower level it might be processed in C or C++ routine/ function.
Hope to help
Giuseppe
07-10-2020 01:40 PM
Thanks for the info. Is just a Lab for production so will see what happens with different codes and on physical. The fact it works on Cisco sandbox but not not EVE-NG suggests maybe something to do with platform or code. Had same issue on older version on EVE-NG so could be that. Like you say worst case just use different name, doesnt sound like are restrictions on naming.
08-24-2020 01:44 AM
