n9k switch/vrf not able to talk to outside
VK20
I have a n9k switch where I have couple of vrf's like management,default,107,108 . Traffic is getting routed via management.
I want to make 107 vrf accessible to outside network.
I have very limited commands in management so can't leak routes.
Giuseppe Larosa
Hello @VK20 ,
This is not what vrf management is intended to be used . It is reserved for out of band management.
You can use a standard VRF or the default Global routing table for route leaking .
So I would suggest you to change your configuration to avoid to use a next-hop in vrf management for your default route.
Move the current configuration of interface under vrf management in a standard interface associated to a standard VRF or GRT.
At that point route leaking becomes possible.
Hope to help
Giuseppe
balaji.bandi
how about leaking the route to GRT
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/200158-Configure-Route-Leaking-between-Global-a.html
Maybe there is a Limitation, if still not working please provide the config to understand.
BB
