12-28-2010 05:10 AM - edited 03-04-2019 10:54 AM
In my test lab I am playing with the Numbered ACL's and Named ACL's.
Both configurations are working BUT , I am sure I do something wrong in the Named ACL's version.
When I reboot or reload the CISCO 1841 ROUTER , I do not have INTERNET anymore , I still have access by TELNET or SSH , but no external communication anymore.
The only way to start the communication again , is by adding :
PERMIT IP ANY ANY
This will ofcourse work , but the funny thing is that when I do a :
NO PERMIT IP ANY ANY
It still works !!!
I have learned by this to always shut down and restart my ROUTER or SWITCH to see if everything still work
Here bellow some parts of the working Numbered ACL's version :
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh port 8096 rotary 1
ip ssh version 2
interface FastEthernet0/0
description DMZ
ip ddns update hostname mlgw.dyndns.info
ip ddns update DynDNS
ip address dhcp
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
Solved! Go to Solution.
12-28-2010 07:04 AM
Didier,
Let's try to clean up the configuration a little before proceeding with your current issue. Now, you are sharing the ACL between your interface and the NAT configuration. That is not a best practice because both ACLs principially serve two different and distinct purposes so it is better to keep them separated. Another issue is that the Cisco NAT implementation does not support the "permit ip any any" type of ACLs and that may account for some of your troubles.
So I suggest you keep your dri-acl-in and dri-acl-out ACLs and use them only on your Fa0/0 interface. However, for the NAT, I strongly recommend creating a separate ACL, for example (you can directly paste the following commands into your configuration mode):
ip access-list standard NAT
permit 192.168.0.0 0.0.255.255
no ip nat inside source list dri-acl-in interface FastEthernet0/0 overload
no ip nat inside source list dri-acl-out interface FastEthernet0/0 overload
ip nat inside source list NAT interface FastEthernet0/0 overload
Try implementing these changes first and only then please try to modify your dri-acl-in and dri-acl-out as you wish them to be.
Best regards,
Peter
12-28-2010 08:26 AM
Hello Didier,
I am glad it started working Thank you and let me also wish you all the very best!
Best regards,
Peter
12-28-2010 07:04 AM
Didier,
Best regards,
Peter
12-28-2010 08:04 AM
Hello Peter,
Thank you for your prompt reply , it works
I have even learn that I can remove some lines in the IN and OUT ACL , I will remove the one that have no matches.
ROUTER1841#sh access-lists
Standard IP access list NAT
10 permit 192.168.0.0, wildcard bits 0.0.255.255 (146 matches)
Extended IP access list dri-acl-in
10 permit udp any any eq domain
20 permit udp any eq domain any (72 matches)
30 permit tcp any any eq domain
40 permit tcp any eq domain any
50 permit tcp any any eq www
60 permit tcp any eq www any (55 matches)
70 permit tcp any any eq 443
80 permit tcp any eq 443 any (403 matches)
90 permit tcp any any eq pop3
100 permit tcp any eq pop3 any (50 matches)
110 permit tcp any any eq smtp
120 permit tcp any eq smtp any (8 matches)
Extended IP access list dri-acl-out
10 permit udp any any eq domain (24 matches)
50 permit tcp any any eq www (82 matches)
70 permit tcp any any eq 443 (318 matches)
90 permit tcp any any eq pop3 (76 matches)
110 permit tcp any any eq smtp (13 matches)
ROUTER1841#
Best Regards and HAPPY NEW YEAR
Didier
12-28-2010 08:26 AM
Hello Didier,
Best regards,
Peter
12-28-2010 02:07 PM
Message was edited by: Didier Ribbens
