Named EIGRP redistribution with different VRF
I'm using Named EIGRP and i need to redistribute from an AS to another but I´m not getting the redistribution done!. For this example I have the network 10.10.6.0 on AS 1 VRF GRE and need the route to be redistributed to AS 110 VRF MPLS.
What i'm missing??
here is my configuration.
router eigrp MPLS
address-family ipv4 unicast vrf MPLS autonomous-system 110
af-interface GigabitEthernet2
summary-address 10.10.0.0 255.255.0.0
exit-af-interface
topology base
redistribute connected
redistribute static
redistribute eigrp 1
exit-af-topology
network 10.8.3.0 0.0.0.7
exit-address-family
address-family ipv4 unicast vrf GRE autonomous-system 1
topology base
redistribute eigrp 110
exit-af-topology
network 192.168.189.0
network 192.168.190.0
exit-address-family
MPLS_1#show ip route vrf GRE 10.10.6.1
Routing Table: GRE
Routing entry for 10.10.6.0/24
Known via "eigrp 1", distance 90, metric 38160000, type internal
Redistributing via eigrp 1
Last update from 192.168.189.14 on Tunnel23, 00:14:09 ago
Routing Descriptor Blocks:
* 192.168.189.14, from 192.168.189.14, 00:14:09 ago, via Tunnel23
Route metric is 38160000, traffic share count is 1
Total delay is 55000 microseconds, minimum bandwidth is 512 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
MPLS_1#
MPLS_1#
MPLS_1#show ip route vrf MPLS 10.10.6.1
Routing Table: MPLS
% Subnet not in table
MPLS_1#
MPLS_1#show ip route vrf MPLS 10.10.0.0
Routing Table: MPLS
MPLS_1#
Julio E. Moisa
The redistribution between the EIGRPs. will not work because they are in differents VRFs so you need to advertise the routes into the VRF, it can be done importing the route-targets, for example:
ip vrf MPLS
rd 1:1
route-target export 1:1
route-target import1:1
ip vrf GRE
rd 2:2
route-target export 2:2
router-target import 2:2
So the solution can be:
ip vrf MPLS
rd 1:1
route-target import 2:2
ip vrf GRE
rd 2:2
route-target import 1:1
Now you can specify the networks to import using maps.
Example: http://packetlife.net/blog/2013/sep/26/vrf-export-maps/
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
ip vrf MPLS
rd 1:1
ip vrf GRE
rd 2:2
ip vrf MPLS
rd 1:1
ip vrf GRE
rd 2:2
Hope it is useful
Thanks!,
    Great advice, I just added a BGP because the routes weren't redistributed directly from eigrp to eigrp.
Here is my final configuration just for the record.
vrf definition EDGE
rd 10.7.0.4:1
route-target export 10.7.0.4:1
route-target import 10.7.0.4:1
route-target import 10.7.0.4:2
address-family ipv4
exit-address-family
vrf definition GRE
rd 10.7.0.4:2
route-target export 10.7.0.4:2
address-family ipv4
exit-address-family
router eigrp EDGE
address-family ipv4 unicast vrf EDGE autonomous-system 110
exit-af-interface
topology base
default-metric 1000 100 250 100 1500
redistribute static
redistribute bgp 6500
exit-af-topology
exit-address-family
topology base
exit-af-topology
exit-address-family
router bgp 6500
bgp log-neighbor-changes
address-family ipv4 vrf EDGE
exit-address-family
address-family ipv4 vrf GRE
exit-address-family
ASR_EDGE1#show ip route vrf EDGE 10.10.6.0
Routing Table: EDGE
Known via "bgp 6500", distance 20, metric 38160000, type external
Redistributing via eigrp 110
Advertised by eigrp 110
Last update from 192.168.189.14 on Tunnel23, 00:23:58 ago
* 192.168.189.14 (GRE), from 0.0.0.0, 00:23:58 ago, via Tunnel23
AS Hops 0
MPLS label: none
ASR_EDGE1#show ip route vrf GRE 10.10.6.0
Routing Table: GRE
Redistributing via eigrp 1, bgp 6500
Advertised by bgp 6500
Last update from 192.168.189.14 on Tunnel23, 00:43:27 ago
* 192.168.189.14, from 192.168.189.14, 00:43:27 ago, via Tunnel23
ASR_EDGE1#
