Named expanded community-list & regular expressions
jhalliodc
I am looking for some insight on why this may not be working.  My platform is a Catalyst 6500, SUP-720, PFC3BXL, MSFC3 running 12.2(33)SXI8.
I have written an expanded named community-list to match a range of communities.
ip community-list expanded SetLocalPref_190 permit 65000:20([0-9][0-9])
This should match 65000:2000 through 65000:2099.
I've built a route-map which is applied outbound to a neighboring iBGP router.  The intention of the route-map and the community-list is to match routes with a community value within the range and set it's local preference to 190 (down from a pre-set default of 200 in my network).
route-map iBGP_OUT permit 10
match community SetLocalPref_190
set local-preference 190
route-map iBGP_OUT permit 20
Long story short, this isn't working and the outbound routes are not having their local preference modified when the prefixes in fact have a matching community.
I also tried ip extcommunities with the same result.
5 Replies 5
milan.kulik
Level 10
Level 10
a) If you issue
sh ip bgp community-list SetLocalPref_190
on your router, are you getting any prefixes listed?
b) You might have forgotten to configure
neighbor ... send-community
towards your iBGP neighbor?
HTH,
Milan
Thank you for taking the time to read and respond to my issue.  Here is what I have conlcuded after receiving your suggestions.
a)  show ip bgp community-list SetLocalPref_190 returns the exact results I would expect and matches all of the prefixes that it should.
b)  my iBGP neighor peer is configured with send-community and does receive these communities.
For what it's worth, I opened a TAC case on this also and their suggestion was to add a plus(+) to the end of the regular expression.  This will match one or more instance, but I/we are not understanding how this will have any effect.
The regular express written either way (with or without the +) returns the expected results when the command "show ip bgp community-list SetLocalPref_190" is issued.
Do you have any other outbound filter for that peering?
-As the route-map for bgp outbound traffic is at the bottom of the outbound order listing and was wondering if this isnt being proceesed becasue of that?
Outbound bgp order::
Distribute list
Prefix-list
Filter-list
Route-map
res
Paul
Kind Regards
Paul
Hi Paul, good point but the route-map is the only filtering applied at the moment.  For what it's worth, the iBGP session was first established with a prefix-list applied outbound which filtered all outbound advertisements and then, the route-map was applied and the prefix-list removed.  The session itself has never been cleared except for soft outbound reconfigurations.
jhalliodc
I got my answer from Cisco TAC and I should have thought of this.  The iBGP session where the route-map is applied is an RR-Client.  Therefore, modifying the local preference on the outbound advertisements wouldn't be possible for the reflected routes.
I'll modify my the local preference on the receiving end.
