named extended access-list in 7200
apingleton
I've got a 7200 vxr that I'm trying to create a named extended access-list in.
I got to conf t
if I go into ip after that the only commands available for access-list are log-update, logging, and resequence.
so if I go back to the main config menu access-list is an available command
but then from the main config menu, if I type: access-list extended eth0_in it says invalid input detected at the carrot marker which is under the first character of the work extended.
also, at the main config menu, if I type: ip access-list extended eth0_in it again give me the invalid input detected at the word extended.
I don't understand what I am missing to get this to work.
I would greatly appreciate any help anyone could give me on this.
Allen
Hello Allen,
>> OMEGA-edge(boot)
your router hasn't loaded a full IOS image this is the meaning of the (boot), so you have a more basic problem then named extended access-list.
check with
show version
show bootvar
you need then to find out if a complete IOS image is present in flash
Hope to help
Giuseppe
9 Replies 9
AhmedSonba
Hello Allen,
Can you post the show version output here to see what Version of IOS yo are running since Named Access list where
introduced in Cisco IOS  Software Release 11.2
Please refer to the following link for more information
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#ipnamacl
Hope it will Help
Ahmed Sonba
Sure, here it is:
IOS (tm) 7200 Software (C7200-KBOOT-M), Version 12.3(6), RELEASE SOFTWARE (fc3)
Thank you for your valuable time,
Allen
Hello Allen,
Its rather strange honstly because I have tried it on my router and its working fine
ip access-list ?
  extended    Extended Access List
  log-update  Control access list log updates
  logging     Control access list logging
  resequence  Resequence Access List
  standard    Standard Access Lis
also I have copied and past your command "ip access-list extended eth0_in"
and it worked just fine on my router .
Can you try it again and copy and post the out come here
Ahmed Sonba
Sure here is the command you listed above:
OMEGA-edge(boot)#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
OMEGA-edge(boot)(config)#ip access-list ?
Here is the command trying to make the ACL:
OMEGA-edge(boot)(config)#ip access-list extended eth0_in
% Invalid input detected at '^' marker.
This is very confusing.
Thank you for your advice on this,
Allen
Hello Allen,
>> OMEGA-edge(boot)
check with
show version
show bootvar
Hope to help
Giuseppe
Okay, I just reset it to defaults, here is the full show version:
Router(boot)#show version
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 11-Feb-04 15:56 by kellythw
Image text-base: 0x60008AF4, data-base: 0x609CA000
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
Router uptime is 18 minutes
System returned to ROM by reload at 12:10:54 UTC Thu Oct 11 2012
System image file is "bootflash:c7200-kboot-mz.123-6.bin"
Last reload reason: Reload command
cisco 7206VXR (NPE400) processor (revision A) with 491520K/32768K bytes of memory.
Processor board ID 36577128
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
6 slot VXR midplane, Version 2.11
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
PCI bus mb0_mb1 has 400 bandwidth points
PCI bus mb2 has 0 bandwidth points
2 FastEthernet/IEEE 802.3 interface(s)
125K bytes of non-volatile configuration memory.
8192K bytes of Flash internal SIMM (Sector size 256K).
And here is the show bootvar:
Router(boot)#show bootvar
BOOT variable does not exist
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
How can I tell if this is not a full version of IOS???????
Hello Giuseppe
Is it possible that Allen has a corrupted IOS image in his flash ? which is resulting this problem
Ahmed Sonba
Hello Allen,
notice the boot in the image filename your router is not running a full IOS image, it is just a bootloader with limited functionality
post
dir bootflash:
dir slot0:
dir slot1:
dir /all
Ahmed:
the full IOS image can be missing or corrupted as you noted.
In a device like this the full IOS image is usually on a PCMCIA flash card that can be easily removed (slot0: or slot1:)
Example:
taken from a C7200 with a full IOS image (some time ago)
mclaren#sh ver
IOS (tm) 7200 Software (C7200-JK9S-M), Version 12.2(15)T14, RELEASE SOFTWARE (fc4)
Compiled Sat 28-Aug-04 16:22 by cmong
Image text-base: 0x60008954, data-base: 0x62146000
ROM: System Bootstrap, Version 11.1(13)CA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
>>BOOTLDR: 7200 Software (C7200-BOOT-M), Version 11.3(2)AA, EARLY DEPLOYMENT, RELEASE SOFTWARE (fc1)
mclaren uptime is 5 days, 4 hours, 59 minutes
System restarted at 11:34:22 UTC Wed Jan 5 2005
>>System image file is "slot0:c7200-jk9s-mz.122-15.T14.bin"
Hope to help
Giuseppe
Hello everyone,
     Just wanted to finish this up. You were right Giuseppe, it wasn't loading the actual IOS image into it.
The router was a spare of someone else in the company given to me to use and they grabbed one that had no image on it.
I've got another one now that works perfectly.
Thank both of you very much for your help with this, and your valuable time in doing so,
Allen
