NAT a specific host outbound to a specific public IP, not the NAT pool
jbankstonps
I have a NAT issue that has been nagging me forever.
My Internet router has nat overload pool configured for PAT outbound from the internal RFC-1918 network. This works fine. I have inside source nat configured for inbound NAT of a public IP to a host inside RFC-1918 IP. This too works fine.
But..... I want that same inside host when going outbound to the internet to nat outbound using the same public as the inside uses. When the inside host goes outbound right now, its public IP is shown as the router's interface IP in the PAT pool and not the static NAT.
IP fudged to protect security.
router outside interface: 1.1.1.1
host IP: 172.16.14.14
static inside source NAT: 172.16.14.14 NATs to 1.1.1.10 for inbound traffic
Can this be done so host's outbound traffic flow shows coming from 1.1.1.10 instead of the 1.1.1.1 PAT pool?
Hello
Deny that inside host from your dynamic pat acl and then create a static nat statement.
Example:
access-list 100 deny host 172.16.14.14 any
access-list 100 permit ip 172.16.14.0 0.0.0.255 any
ip nat inside source-list 100 interface <wan> overload
ip nat inside source static 172.16.14.14 1.1.1.10
Kind Regards
Paul
7 Replies 7
small lab and share result soon
I do small lab and success
in dynamic NAT instead of use list use
route-map
as following
 route-map
ANY interface X/X overload
route-map ANY permit 10
match ip address 100
ip access-list extended 100
permit ip <LAN><LAN MASK> any
not what I was looking for.
all other inside hosts go outbound using the PAT interface nat but I need the one host to go outbound using a static nat so that the public internet sees the host's public IP as the 1.1.1.10 while the other inside hosts' will be shown as coming from the 1.1.1.1 interface PAT IP. I tried a
 route-map
to force the host's nat that way and it didn't work.
hghghghghghgh.pngkkkkkkkkkkkkkkk.pngusing the static NAT I can telnet from R2 to R3
jjjjjjjj.pngUsing dynamic NAT I can ping from R3 to R2
Hello
Example:
Kind Regards
Paul
with a slight twist...... I had to remove the static nats being used at the port level and then put in one single nat IP to IP, without any extendable port nats
ip nat inside source static tcp 172.16.14.14 25 1.1.1.10 25 extendable
and all the other ports nats were replaced with a single
and it works now!
very cool, thank you, just some additional feedback as the port nats were part of the complication.
it work what, can you ping now from 172.16.14.14 to 8.8.8.8 ? or it work can you access from Out to 172.16.14.14 using port 25 ?
can you elaborate?
