NAT access-list deny entry being skipped
a.banta01
Having some issues and super frustrated. Been searching the web for last four hours trying to figure out why.
Set up a router with two networks. Added NAT everything works as expected. All traffic is NAT’d
Net A ------ Gi0-Router-Gi1------- Net B, Internet
Gi0/0/0 is nat inside
Gi0/0/1 is nat outside
Traffic to the internet works fine, NAT is great. Problem is, if Net A communicates with a host on Net B, the address is NAT’d – Hosts on Net B need to access internal network of Net A, but the return traffic is now NAT’d.
One would think throw on a NoNAT, simple deny entry before the permit in the ACL – and for whatever reason… it doesn’t work.
interface GigabitEthernet0/0/0
 ip address 10.1.32.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/0/1
 ip address 192.168.0.1 255.255.255.0
 ip nat outside
ip nat inside source list 101 pool NETBPool
ip nat pool NETBPool 192.168.0.10 192.168.0.254 netmask 255.255.255.0
ip access-list extended 101
 deny   ip 10.1.32.0 0.0.0.255 192.168.0.0 0.0.0.255
 permit ip 10.1.32.0 0.0.0.255 any
If 10.1.32.11 tries to ping 192.168.0.3, the ping goes through, and is NAT’d to an IP in the pool (.10, .16, etc). It looks like the deny entry in ACL 101 is being skipped and the permit entry is being used.
lab-r1#sh ip nat trans | i 32.11.*0.3
icmp 192.168.0.11:1        10.1.32.11:1          192.168.0.3:1         192.168.0.3:1
I've gone as far as using exact host addresses for 10.1.32.11 and 192.168.0.3 on the deny entry, and the issue persists. As long as there is a permit rule after a deny, the deny is ignored.
lab-r1#sh access-li 101
Extended IP access list 101
10 deny ip host 10.1.32.11 host 192.168.0.3
15 deny ip any host 192.168.0.3
20 permit ip any any
lab-r1#sh ip nat trans | i icmp
lab-r1#
Can anyone provide any insight or Cisco documentation on why NAT is ignoring a deny entry?
ISR4321
03.16.04b.S - Yeah I know, its a lab
16 Replies 16
sdroy
n Cisco NAT configurations, the ACL used for NAT is evaluated differently than a standard ACL applied to an interface. Specifically, NAT ACLs are used to define which traffic should be translated, and the deny statements in these ACLs do not block traffic—they simply exclude it from being NAT'd. This means that even though your ACL has a deny entry, the traffic is still allowed to pass through the router; it just bypasses NAT translation.
To resolve this, you may need to implement a separate ACL on the interface to explicitly block the traffic you want to deny. Alternatively, you could use route maps with NAT to gain more granular control over the traffic. For more detailed guidance, you can refer to Cisco's documentation on NAT and ACL behavior, such as
https://www.cisco.com/c/en/us/td/docs/routers/asr920/configuration/guide/sec-data-acl/17-1-1/b-sec-data-acl-xe-17-1-asr920/b-sec-data-acl-xe-17-1-asr920_chapter_00.html
Shuvodip Roy
Correct - the ACL in this case is not for allowing or denying traffic - only as a traffic eligibility selection for NAT.
The problem is, the deny entry is NOT bypassing NAT.
Hello
lab-r1#
When using NAT the external network in most use cases is not even aware of the network being translated, so in your scenario 10.1.32.x/24 is the hidden from 192.168.0.x/24
So of you do not wish to NAT on a certain inside host then the external networks will need to be aware and able to reach that inside NON translated host, but the problem you have is you have hosts on a directly connected "outside" network you wish not to be natted but you are using that same network for translation.
Note you can NAT on ANY network as long as its reachable externally AND its originates from you own rtr also the nat acl needs NOT to include an "any any" statement.
Example1:
lab-r1
access-list 101 deny ip host 10.1.31.11 any
access-list 101 permit ip 10.1.31.0 0.0.0.255 any
external rtr
ip route 10.1.31.11 255.255.255.255 x/x 192.168.0.1
Example2:
lab-r1
no ip nat pool NETBPool
ip nat pool NETBPool 172.16.0.10 172.16.0.254 netmask 255.255.255.0
external rtr
ip route 172.16.0.0 255.255.255.0 x/x  192.168.0.1
Kind Regards
Paul
With the experienced problem, neither example will work - the router is ignoring the deny entry and still applying NAT, that is the issue.
If the router would follow the ACL in the current setup or either example I see no issues, but therin lies the problem.
Hello
Well here the problem , either solution i submitted should work unless you are not sharing all the information on your OP.
Post a simple topology diagram showing what you are trying to accomplish, maybe it will show why those examples are not working
Kind Regards
Paul
The third line on the post was a simple text diagram. I'll try to create an image and upload it.
My point on your solutions not working - and I'll try to be concise:
The router is ignoring ACL deny entries for NAT. Your solutions use ACL deny entries. The router will ignore those. That issue is the entire purpose of the post.
10 deny ip host 10.1.32.11 host 192.168.0.3 <-------------- Deny rule in ACL for NAT, first entry in ACL
The ACL above used in NAT is supposed to deny NAT from being performed (No-NAT) for traffic sourced from 10.1.32.11 destined to 192.168.0.3 - and its not working:
icmp 192.168.0.11:1 10.1.32.11:1 192.168.0.3:1 192.168.0.3:1  <-------- Router ignores deny rule, and still performs NAT
balaji.bandi
In your use case,
1. why not DSL router does all NAT stuff, Let Leave the Router act as a router
2. other option @paul driver  suggested same way below similar :
DSL Router you need route back to 10.1.32.0/24 towards 192.168.0.1
on the Router
ip nat inside source list 100 interface Ethernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.2
access-list 100 deny ip 10.1.32.0 0.0.0.255 host 192.168.0.3
access-list 100 permit ip 10.1.32.0 0.0.0.255 any
Other think i can think until we hitting any bug on that code.
BB
In the home lab, the DSL router is a simple router provided by the ISP which is locked down and cannot do routing, which is why the lab-r1 has to NAT anything behind it.
Again, the router is ignoring deny entries
is a deny entry and will be ignored by the router.
I upgraded from 03.16.04b.S to 16.9.8 and the issue persists.
I have the same version of the code Router CSR in the Lab, and it works as expected with the routing back from the DSL router.
since you have no access to DSL router, we may need to think different way. since DSL router or PC not aware 10.1.320 network and it will send out.
For testing :
on the PC 192.168.200.3
can you add route  10.1.32.0/24 towards 192.168.200.1  and test it
BB
Issue persists. The router is still changing the IPs of 10.1.32.0/24 despite the NAT ACL Denies
For testing :
on the PC 192.168.0.3
can you add route  10.1.32.0/24 towards 192.168.0.1  and test it
as per we know we are trying only 1 host that is 192.168.0.3(my correction i was mentioned 192.168.200.3)
Now we see Lot of IP NAT entries here on your list, how many interface you have ?
simple test to prove use 1 of the PC and test it as below :
On the PC 192.168.0.3 add on Windows route
route add 10.1.32.0 mask 255.255.255.0 1192.168.0.1
BB
Try
1- Remove ip nat outside from interface
2- Clear ip nat translate
3- add ip nat outside to interface again
Then check again
MHM
Tried those steps, issue persists. For whatever reason, the router is ignoring NAT deny ACL entries.
Do show Ip access list,
it can the order you add deny is come after permit.
Share output here
Also share
Debug ip nat
MHM
