NAT all source IP to range 10.1.1.3-10.1.1.254 of WAN interface
getaway51
Level 2
Level 2
I need to NAT all incoming traffic from LAN to outgoing WAN interface but not to source IP of WAN interface(10.1.1.2) but to dynamic range of 10.1.1.3-10.1.1.254.
May I know how the config shld looks like?
do you mean a NAT pool ?
interface FastEthernet0/0
ip address 10.1.1.2 255.255.255.0
ip nat outside
interface FastEthernet0/1
ip nat inside
ip nat pool ISP_POOL 10.1.1.3 10.1.1.254 netmask 255.255.255.0
ip nat inside source list 1 pool ISP_POOL overload
access-list 1 permit 192.168.1.0 0.0.0.255
If traffic initiated from WAN so tht dest IP NAT 10.1.1.3->192.168.1.2, wht config need to add in below?
ip nat outside
ip nat inside
RicardoSN
Hi gateway51,
With the little information given, I would say you could exclude with an standard ACL the /32 IPs (.1, .2 and .3) you don't want to translate, denying those on the first three entries and then in the fourth entry permiting the whole 10.1.1.0/24 block
Something like this:
access-list 50 deny host 10.1.1.1
access-list 50 deny host 10.1.1.2
access-list 50 deny host 10.1.1.3
access-list 50 permit 10.1.1.0 0.0.0.255
Then you should use that ACL on the global config command "ip nat inside source list 50...".
But maybe i didn't get very well what you really need, please try to give us more information to work with if that's the case.
-Ricardo S.N., Regards!
