NAT and radius
leungcm
We setup a radius server for authentication. R1 is Internet gateway, R2 is behind the internet gateway with internal segment (192.168.x.x). We can use the radius to
auth for R2. It means that we can telnet the R2 and using radius account to login the R2 router. However, it fails to auth when login to R1. Detail router config please refer following.
We guess that the issue is the NAT but I have no any idea to solve it, please advise
Best regards
R1
aaa group server radius RadiusServers
server 192.168.10.10 auth-port 1812 acct-port 1813
interface GigabitEthernet0/1
ip address 195.x.x.113 255.255.255.240
ip route 0.0.0.0 0.0.0.0 <isp gateway>
ip route 192.168.10.10 255.255.255.255 195.x.x.114
R2
interface GigabitEthernet0/0
ip address 195.x.x.114 255.255.255.240
ip nat outside
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 195.x.x.113
ip nat pool NAT_OUT 195.x.x.114 192.x.x.114 netmask 255.255.255.240
ip nat inside source route-map nonat pool overload NAT_OUT
route-map nonat permit 10
match ip address 155
access-list 155 deny ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 155 deny ip 192.168.10.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 155 permit ip 192.168.10.0 0.0.0.255 any
radius server
ip address: 192.168.10.10
default gateway point to 192.168.10.1
Danilo Dy
1. What RADIUS are you using? Did you check if it has a client configuration for 195.x.x.113? It may have a client configuration only for 192.168.10.1 or 192.168.10.0/24
2. Since you NAT to 195.x.x.114, I suggest you change the config in R1 from;
to;
server 195.x.x.114 auth-port 1812 acct-port 1813
I think some IOS can add "radius source-interface" command, you may want to include this in;
R1
ip radius source-interface GigabitEthernet0/1
R2
Dandy
the radius is freeradius. the radiuscan can auth with all internal routers 192.168.x.x). no matter the router in tw or usa. However fail to auth the internet gateway (with "ip nat outside" command).
Could you give me some idea regarding the "radius source-interface"? do we change the NAT setting? pls advise
Best regards
