nat and tunnel
leungcm
We would like to config following:
1. setup tunnel in between R1 and R2
2. R1 is "ip nat inside" and R2 is "ip nat oustde"
3. I would like all users to access "66.221.132.2" this server, it must go to tunnel and through R2, R3 to outside internet to 66.221.132.2
following is the config. however, it does not work. what is missing? detail please refer attached file. please advice
Best regards
---- config
R1
interface Tunnel 1
ip address 172.16.1.1 255.255.255.252
ip nat outside
tunnel source 192.168.1.1
tunnel destination 192.168.10.1
ip route 66.221.132.2 255.255.255.255 172.16.0.2
R2
interface FastEthernet0
ip address 64.1.1.1 255.255.255.240
ip nat outside
crypto map mymap ! had already had vpn
interface FastEthernet1
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Tunnel 1
ip address 172.16.1.2 255.255.255.252
ip nat outside
tunnel source 192.168.10.1
tunnel destination 192.168.1.1
ip nat pool test 64.1.1.1 61.1.1.1 netmask 255.255.255.240
ip nat inside source list 10 pool test overload
ip nat inside source list 20 interface tunnel 1 overload
access-list 20 permit 172.16.0.0 0.0.0.255
access-list 10 permit 192.168.10.0 0.0.0.255
smahbub
Level 6
Level 6
Remove the command - ip nat inside source list 20 interface tunnel 1 overload
