One private IP NAT to multiple public IPs?
jackawang
Level 5
Level 5
I have a requirement to setup a network so that an internal server communicates with outside world through different WAN networks. I have three separate WAN connections terminated on a single Cisco 6500. The internal network also connects to the same switch.
External VLANs: Ingress, Egress and Management
Internal VLAN: Internal
Requirements:
1. Management traffic can only talk to the internal server(s) via Management WAN;
2. Application traffic can only talk to the internal server(s) via Ingress WAN;
3. Outbound traffic originated from internal servers has to go through Egress WAN;
4. Internal servers use private IP addresses
For example, I have:
Servers on Internal VLAN:
10.0.0.2
10.0.0.3
10.0.0.4
The mangement traffic (i.e. SNMP, ssh) uses the following public IPs to reach each server:
5.5.5.2
5.5.5.3
5.5.5.4
The application traffic (i.e. www, ftp) uses the following public IPs to reach each server:
6.6.6.2
6.6.6.3
6.6.6.4
The traffic initiated from the servers uses the following public IPs to access the Internet:
7.7.7.2
7.7.7.3
7.7.7.4
Given the requirements above, how do I design/configure my switch to achieve the goal? I've done some searches on the forum with no luck. Please kindly advise. Any hint would be appreciated!
fmeetz
Level 4
Level 4
Create a topology diagram and lay the criterria from there you can start the designing:
You can refer the link for desining the network
http://www.cisco.com/en/US/products/hw/switches/ps708/tsd_products_support_design_technotes_list.html
