NAT behind VPN
hsnanua2011
Dear all,
I have a small Q,
in this scenario, we have a customer. The customer, does not want any private ip addresses sent over thru the IPSEC VPN. That is a problem, as all the servers has private IPs. Like 10.x.x.x.
A small illustration:
(LAN)------------------>VPN router---------------------->customer VPN router
My proposal, is that i introduce a router between the LAN netwook and my VPN router to do the NAT, converting the private ip addresses into public IP addresses and then sending it over the VPN.
(LAN)----------->NAT router----------->VPN router-------------->customer VPN router
Would this be possible?
Jon Marshall
Why not just do the NAT on the VPN router at your end ?
Jon
hsnanua2011
I am not allowed to play with the VPN Asa router.
Well it seems a bit expensive just to buy a router for NAT when you have a perfectly good ASA but yes you use a router for that function. You could do the Natting there.
Couple of things -
1) the public IPs you use cannot be part of a subnet that you have actually assigned to a physical interface on the ASA ie. you would need a separate subnet.
2) you would then have a route on the ASA router for this public IP subnet pointing to the outside interface of the router.
So even with a router you still need to make a modification to the ASA device. Personally i would just get whoever is allowed to play with the ASA to do the NAT on there. What you are proposing just adds unnecessary complication.
Jon
Hi Jon,
I manage to get access to the ASA, and now I shall use NAT on the ASA.
So, the diagram would be
Inside network ------------------->ASA-----------------------------------------VPN---------------------->Customer router
     10.x.x.x-----------------------> NAT (6.7.x.x)--------------------------------------------------------->
Sp, basically, i shall NAT my 10.x.x.x network ip into a puclic IP address (say, 6.7.x.x.) before sending it over on the VPN.
This is quite simple right? Anything I need to be aware of?
Thanks!
