multilink lost fragments and out of sequence
Hi ,
I m not able to add 4th link in multilink group .while adding getting below errors -
routerA
Cisco 3845
flash:c3845-adventerprisek9-mz.124-15.T1.bin
routerB-
Cisco 7206VXR (NPE-G1)
disk2:c7206-VXR--advipservicesk9-mz.124-24.T3.bin
error Logs from routerA while adding 4th link in multilink ==>
CR01#sh ppp multilink
Multilink2
  Bundle name: MUM
  Remote Endpoint Discriminator: [1] MLD
  Local Endpoint Discriminator: [1] RAN
  Bundle up for 9w4d, total bandwidth 6144, load 47/255
  Receive buffer limit 36000 bytes, frag timeout 1000 ms
    0/0 fragments/bytes in reassembly list
    61 lost fragments, 43440 reordered
    57/27662 discarded fragments/bytes, 0 lost received
    0x9DFE23 received sequence, 0x618A6C sent sequence
  Member links: 3 active, 1 inactive (max not set, min not set)
    Se0/2/1:0, since 2w3d
    Se0/2/0:0, since 2w3d
    Se0/1/0:0, since 1w2d
    Se0/0/1:0 (inactive)
No inactive multilink interfaces
CR01#
AI-CR01#sh log
Syslog logging: enabled (12 messages dropped, 9 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level critical, 29 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 54106 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 525039 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
    Trap logging: level notifications, 8086 message lines logged
        Logging to 10.89.16.102  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              8086 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging to 10.2.26.156  (udp port 514,  audit disabled,
              filtering disabled
        Logging to 10.2.26.157  (udp port 514,  audit disabled,
              filtering disabled
Log Buffer (4096 bytes):
2 MLP: Dropped link Se0/3/1:0 from bundle MUM_CR01_MLD
Aug 12 23:50:50.301 IST: Se0/3/1:0 MLP: Request add link to bundle
Aug 12 23:50:50.301 IST: Se0/3/1:0 MLP: Adding link to bundle
Aug 12 23:50:50.301 IST: Se0/3/1:0 MLP: Computed frag size 7672 exceeds MTU, changed to 1496
Aug 12 23:50:50.301 IST: Mu2 MLP: Added link Se0/3/1:0 to bundle MUM_CR01_MLD
Aug 12 23:50:50.301 IST: Se0/3/1:0 MLP: Request drop link from bundle Mu2
Aug 12 23:50:50.301 IST: Mu2 MLP: Removing link Se0/3/1:0 from bundle MUM_CR01_MLD
Aug 12 23:50:50.301 IST: Mu2 MLP: Dropped link Se0/3/1:0 from bundle MUM_CR01_MLD
Aug 12 23:50:52.357 IST: Se0/3/1:0 MLP: Request add link to bundle
Aug 12 23:50:52.357 IST: Se0/3/1:0 MLP: Adding link to bundle
Aug 12 23:50:52.357 IST: Se0/3/1:0 MLP: Computed frag size 7672 exceeds MTU, changed to 1496
Aug 12 23:50:52.357 IST: Mu2 MLP: Added link Se0/3/1:0 to bundle MUM_CR01_MLD
Aug 12 23:50:52.357 IST: Se0/3/1:0 MLP: Request drop link from bundle Mu2
Aug 12 23:50:52.357 IST: Mu2 MLP: Removing link Se0/3/1:0 from bundle MUM_CR01_MLD
Aug 12 23:50:52.357 IST: Mu2 MLP: Dropped link Se0/3/1:0 from bundle MUM_CR01_MLD
Aug 12 23:50:54.417 IST: Se0/3/1:0 MLP: Request add link to bundle
Aug 12 23:50:54.417 IST: Se0/3/1:0 MLP: Adding link to bundle
Aug 12 23:50:54.417 IST: Se0/3/1:0 MLP: Computed frag size 7672 exceeds MTU, changed to 1496
Aug 12 23:50:54.417 IST: Mu2 MLP: Added link Se0/3/1:0 to bundle MUM_CR01_MLD
Aug 12 23:50:54.417 IST: Se0/3/1:0 MLP: Request drop link from bundle Mu2
Aug 12 23:50:54.417 IST: Mu2 MLP: Removing link Se0/3/1:0 from bundle MUM_CR01_MLD
Aug 12 23:50:54.417 IST: Mu2 MLP: Dropped link Se0/3/1:0 from bundle MUM_CR01_MLD
Aug 12 23:50:56.477 IST: Se0/3/1:0 MLP: Request add link to bundle
Aug 12 23:50:56.477 IST: Se0/3/1:0 MLP: Adding link to bundle
Aug 12 23:50:56.477 IST: Se0/3/1:0 MLP: Computed frag size 7672 exceeds MTU, changed to 1496
Aug 12 23:50:56.477 IST: Mu2 MLP: Added link Se0/3/1:0 to bundle MUM_CR01_MLD
Aug 12 23:50:56.481 IST: Se0/3/1:0 MLP: Request drop link from bundle Mu2
Aug 12 23:50:56.481 IST: Mu2 MLP: Removing link Se0/3/1:0 from bundle MUM_CR01_MLD
Aug 12 23:50:56.481 IST: Mu2 MLP: Dropped link Se0/3/1:0 from bundle MUM_CR01_MLD
Aug 12 23:50:57.161 IST: Se0/3/1:0 MLP: Removed interface from multilink group Mu2
Aug 12 23:50:58.821 IST: %SYS-5-CONFIG_I: Configured from console by kailashs on vty1 (10.89.16.110)
Aug 12 23:50:59.425 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/3/1:0, changed state to up
Aug 12 23:55:02.708 IST: Se0/3/1:0 MLP: Added interface to multilink group Mu2
Aug 12 23:55:03.708 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/3/1:0, changed state to down
Aug 12 23:55:05.276 IST: %SYS-5-CONFIG_I: Configured from console by kailashs on vty1 (10.89.16.110)
Aug 12 23:55:05.768 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/3/1:0, changed state to up
Aug 12 23:57:49.332 IST: Mu2 MLP: Lost fragment timeout, seq 9BAC33
Aug 12 23:57:49.332 IST: Mu2 MLP: Discard reassembled packet
Aug 12 23:58:01.324 IST: Mu2 MLP: Lost fragment 9BB323 (all links out of sequence)
Aug 12 23:58:01.324 IST: Mu2 MLP: Begin bit lost, discard fragment 9BB324
Aug 12 23:58:46.146 IST: Mu2 MLP: Lost fragment 9BBF35 (all links out of sequence)
Aug 12 23:58:46.146 IST: Mu2 MLP: Begin bit lost, discard fragment 9BBF36
Aug 13 00:07:39.588 IST: Mu2 MLP: Lost fragment 9BCC6A (all links out of sequence)
Aug 13 00:07:39.588 IST: Mu2 MLP: Begin bit lost, discard fragment 9BCC6B
Aug 13 00:11:03.245 IST: %SYS-5-CONFIG_I: Configured from console by kailashs on vty1 (10.89.16.110)
Aug 13 10:39:49.626 IST: %SYS-5-CONFIG_I: Configured from console by navaneethr on vty0 (10.89.16.110)
Aug 13 10:40:11.371 IST: %SYS-5-CONFIG_I: Configured from console by navaneethr on vty0 (10.89.16.110)
Aug 13 22:35:01.747 IST: %SYS-5-CONFIG_I: Configured from console by kailashs on vty0 (10.89.16.110)
Aug 14 00:24:47.620 IST: %SEC_LOGIN-4-LOGIN_FAILED: Login failed [user: ashoks] [Source: 10.44.61.16] [localport: 22] [Reason: Login Authentication Failed] at 00:24:47 IST Sun Aug 14 2011
Thanks for any help
If  possible  I  would  advise  you  to  rebuild  the  mutlilink,
Delete  existing MUltilink and  add  one  by  one  again--  all  4 links.
Those  lost  fragments  and  reordered errors  are  ok,it  will not  cause 4th  link  to  be inactive.
~Jyoti
