NAT Box-to-box HA runtime priority
JonnyNet
I have an on going minor issue with the NAT Box-to-box HA feature on 15.5 ASR 1001-X.
If there is a disruption on the WAN side (rii 2 in my case) of the primary router (redundancy priority configured as 120) and therefore a decrement of 100 occurs (see configuration below), even if the interface comes back up the runtime priority gets stuck at 20 on the primary router and it won't automatically become active again. Reloading the redundancy group on the primary router makes it the active again (probably because it is comparing it's configured priority of 120 vs the secondary router which has a configured priority of 80, but when looking under the faults, the runtime priority is still stuck at 20 and I would expect it to revert back to 120.
Configuration and status after the event has occurred is posted below.
Primary
interface Ethernet0/0
 ip address 192.168.0.1 255.255.255.0
interface Ethernet0/1
 ip nat inside
 ip virtual-reassembly in
 redundancy rii 1
 redundancy group 1 ip 192.168.1.254 exclusive decrement 100
interface Ethernet0/2
 ip address 192.168.2.1 255.255.255.0
 ip nat outside
 redundancy rii 2
 redundancy asymmetric-routing enable
 redundancy group 1 decrement 100
(config-red-app-grp)#do sh run | s red
redundancy
 application redundancy
  group 1
   name group1
   preempt
   priority 120
   control Ethernet0/0 protocol 1
   data Ethernet0/0
   asymmetric-routing interface Ethernet0/0
   asymmetric-routing always-divert enable
 redundancy rii 1
 redundancy rii 2
(config-red-app-grp)#do show redundancy application group 1
Group ID:1
Group Name:group1
Administrative State: No Shutdown
Aggregate operational state : Up
My Role: ACTIVE
Peer Role: STANDBY
Peer Presence: Yes
Peer Comm: Yes
Peer Progression Started: Yes
RF Domain: btob-one
RF state: ACTIVE
Peer RF state: STANDBY HOT
(config-red-app-grp)#do show redundancy application fault group 1
Faults states Group 1 info:
Runtime priority: [20]
RG Faults RG State: Up.
Total # of switchovers due to faults:           0
Total # of down/up state changes due to faults: 0
Secondary
 ip address 192.168.0.2 255.255.255.0
 ip address 192.168.1.2 255.255.255.0
 ip nat inside
 redundancy rii 1
 ip address 192.168.2.2 255.255.255.0
 ip nat outside
 redundancy rii 2
redundancy
  group 1
   name group1
   preempt
   data Ethernet0/0
 redundancy rii 1
 redundancy rii 2
Group ID:1
Group Name:group1
My Role: STANDBY
Peer Role: ACTIVE
Peer Presence: Yes
Peer Comm: Yes
RF Domain: btob-one
Peer RF state: ACTIVE
Runtime priority: [100]
How can the runtime priority be reset? and how can I determine what is holding it down from the configured value if I was not catching logs previously?
Many thanks!
Tinashe Ndhlovu
I can only give you pointers at this time i will sit down and relook at this but i believe you need to use track object for this to work i mean how are you telling the preempt process that the interface is up without tracking.. i could be wrong but i think this could fix your issue
at first glance, the problem seems to be that you are using the same interface for control and data. The protocol instance is tied to the control interface, not the data interface, so I am not sure this works.
Can you try and create a separate data interface ?
I should have mentioned something in my first post. The configuration I posted on this forum is not the full production configuration but something I put together in a lab to reproduce the issue. In the production environment I do indeed have those on separate interfaces (Gi0/0/4.1 .2 and .3) but have the same problem. Thanks for the suggestion though, I will configure the lab closer to the production configuration just incase. In additional, I also have track statements on the LAN interfaces but I believe this is just to decide which router should advertise the NAT pool depending on which is primary? Here is what I have on the production router (with some IP addresses omitted) for the two LAN interfaces:
track 1 ip route 192.168.1.254 255.255.255.255 reachability
track 3 ip route 192.168.3.254 255.255.255.255 reachability
ip route PUBLIC_NAT_POOL Ethernet0/1 track 1
ip route PUBLIC_NAT_POOL Ethernet0/3 track 3
I don't have a track on the WAN interface (Ethernet0/2) but not sure if that is necessary.
Many Thanks,
Jonathan
