NAT Box-to-Box High Availability on Asymmetric-Routing Question
dane.davis1
I see this topology below is possible:
Notice the Asymmetric Routing interface in use.
The two WAN-facing interfaces are both independent, and do not share a common virtual IP address
The two LAN facing interfaces share a common virtual IP address.
My question: Is it possible to modify this design, for the LAN facing interfaces to both be independent, without requiring a virtual IP address shared between them? Will this break the NAT HA design?
This is the design I need to am hoping to accomplish:
Notice the is LAN A and LAN B (no virtual IP on the LAN side)
Information source:
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/15-mt/nat-15-mt-book/iadnat-b2b-ha.html.xml
0 Replies 0
