NAT Config Issue for DVR
Bhaseeth Ali
Hai all,
Iam new to Cisco , I have an Cisco 2811 Router with 2 ethernet ports:
Below is my config :
2  ethernet ports on my router
1 port 0/0 directly connected to ISP link
WAN IP is configured as 122.183.1xx.6 ip and gateway is 122.183.1xx.5
1 port 0/1 connected to my lan that is 192.168.1.0 network
Lan IP for 0/1 port is 192.168.1.200
Internet is working fine
If do an What is my IP ?
I get ip as 122.183.1xx.42
My ISP says its an LAN IP Pool :
122.183.1xx.43 - 47
Now just i want to view my DVR outside my network from internet ?
Do i need an NAT to view my DVR ?
If i use an DYDNS ID my router 2811 filters the port 37777.how to unblock it
DVR IP is 192.168.1.242 port no 37777
what is the procedure for nat it to an static ip pool got from my isp ? how to unblock the port 37777?
Kindly help to sort it out..
Thank You.....
did you try the previous suggestion? I requested for the outputs but i do not see any.
To check if your ISP is blocking or not do the following:
1. create an ACL as follows
   access-list 199 permit tcp any host 122.183.1xx.43 eq 37777 log
   access-list 199 permit ip any any
2. apply it to the outside interface
    router(config)# int fa0/1
           (config-if)#ip access-group 199 in
3. Now Telnet 122.183.1xx.43 port 37777 from outside
4. Check if th packets are hitting you box by issuing the following command:
   show ip access-list 199
if you see hit counts increasing on the ACL first line that meanas your ISP is not blocking the traffic.
After you have done this. Please send the latest config.
13 Replies 13
cadet alain
ip nat inside source static tcp 192.168.1.242 37777 interface f0/0 37777
Regards.
Alain
varununiyal
  If you know the protocol (TCP or UDP) that DVR is listening on:
ip nat inside source static 192.168.1.242 37777 122.183.1xx.6 37777
if not then use one to one but dont use the same IP as WAN IP
ip nat inside source static 192.168.1.242  122.183.1xx.y <<< public ip different than wan ip used above
This configuration is not working
if do an nat
ip nat inside source static 192.168.1.242 37777 122.183.181.4x 37777
then also the port is filtered if i do an portqry  37777 port.
if i ping that ip i can get reply
if i do an portqry for ip 122.183.181.4x like port 25 , 110 i get listenting.
there is only one acl 1 show sdm category=2
Kindly reply asap
Try this:
If DVR is listening on TCP then From the router Telnet DVR ip on port 37777
#telnet 192.168.1.242 37777
this will tell you if the tcp port is actually open on the DVR. If it says connection refused that means DVR is not listening on port 37777 and you will need to open it on the DVR box
Also after you have made the config and when  you try fto access the DVR from outside take and post the following output
"show ip nat translations"
tcp 122.183.181.4x:37777 192.168.1.242:37777 ---             ---
i can telnet from router to dvr 192.168.1.242 37777 it says open.
thank you.
Hi Baseeth,
Is your configuration is
interface port 0/0
ip nat outside
interface port 0/1
ip nat inside
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
This is my config kindly help,
port 37777 cannot be accessed from  outside it say filtered when we to an portqry
Using 1961 out of 196600 bytes
version 12.4
hostname llmkolthur
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging buffered
enable secret 5 $1$jmsa$EorwYutDqRhbY0DgBv5cG0
enable password enable
no aaa new-model
clock timezone Chennai 5 30
dot11 syslog
ip source-route
ip cef
ip name-server 203.145.184.13
ip name-server 203.145.184.32
username admin privilege 15 view root secret 5 $1$SXdp$so2azlWt569tN3Tdy7HbY1
archive
log config
  hidekeys
interface FastEthernet0/0
description LAN Connection - LLM Kolathur Works$ETH-LAN$
ip address 122.183.1xx.46 255.255.255.248 secondary
ip address 192.168.1.200 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description WAN Connected to Airtel Leased Line - LLM Kolathur Works$ETH-WAN$
ip address 122.183.1xx.6 255.255.255.252
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 122.183.1xx.5
ip http server
no ip http secure-server
ip nat pool Internet_Access 122.183.1xx.42 122.183.1xx.42 netmask 255.255.255.24
8
ip nat inside source list 1 pool Internet_Access overload
ip nat inside source static tcp 192.168.1.242 37777 122.183.1xx.43 37777 extendable i have added this one only
ip nat inside source static tcp 192.168.1.108 37777 122.183.1xx.46 37777 extenda
ble
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
can you modify access-list 1 as follows:
access-list 1 deny host 192.168.1.242
Ideally the static entry should take preference but this config will make sure that dynamic is not used.
Also please post the following ouput when you try to telnet on 122.183.1xx.43 on port 37777 from outside world:
show ip nat statistics
show ip nat translation | include 192.168.1.242
Nothing works
when do an telnet from outside
could not open connection to the host on port 37777
what wrong with config ?
Why the port is filtered ?
is their any thing wrong in acl ?
is their an problem with my isp migth be blocking port 37777?
please revert asap!
thank you
Dear Sir,
This is the latest config:
Current Configuration after creating ACL
llmkolthur#show running-config
Building configuration...
Current configuration : 2086 bytes
version 12.4
hostname llmkolthur
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
dot11 syslog
ip source-route
ip cef
archive
log config
hidekeys
ip nat inside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
ip http server
8
ble
ble
control-plane
line con 0
line aux 0
line vty 0 4
login
end
IP ACCESS LIST LOG AFTER TRY TELNET FROM PUBLIC NETWORK
llmkolthur#show ip access-lists 199
Extended IP access list 199
10 permit tcp any host 122.183.1xx.43 eq 37777 log (6 matches)
20 permit ip any any (207 matches)
20 permit ip any any (245 matches)
10 permit tcp any host 122.183.1xx.43 eq 37777 log (9 matches)
20 permit ip any any (265 matches)
TELNET RESULT :
Connecting To 122.183.1xx.43...Could not open connection to the host, on port 37
777: Connect failed
But i can ping this ip 122.183.1xx.43
If i do an telnet from router to DVR with local ip telnet192.168.1.242 on port 37777 ---- it say open
If i do an telnet from router to DVR with local ip telnet192.168.1.242 on port 80---- it say it
llmkolthur#telnet 192.168.1.242
Trying 192.168.1.242 ... Open
(none) login:
I tried these way I have created nat to access the router through telnet port 23 on ip 122.183.1xx.43
ip nat inside source static tcp 192.168.1.200 23 122.183.1xx.43 23
192.168.1.200-----> Local ip of router
From any public from outside i can telnet the port 122.183.1xx.43 23 and can successfully access the router
So NAT through accesslist is working, iam i rite ?
Thank You , awaiting for ur reply
Good to see that problem is resolved Bhaseeth.
Thanveer
Thank you all,
      Atlast Dvr is up and running through NAT
      Issue is Gateway wrongly configured in the DVR
