NAT configuration behind pppoe with virtual server
tkalfaoglu
hi there.. my router is handling pppoe, NAT, and DHCP server..
My local LAN is 192.168.1.x and it's behind that NAT.
I'm trying to enable access to a DNS server on this LAN, 192.168.1.191 tcp/udp 53.
Here is what I have, access from WAN to that DNS server is not currently possible.. Any ideas why?
version 15.4
boot-start-marker
boot-end-marker
enable secret  XXXX
enable password XXXX
no aaa new-model
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp excluded-address 192.168.1.191
ip dhcp pool 192.168.1.0/24
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.191 176.9.1.236
netbios-name-server 192.168.1.191
domain-name xxxxx.net
ip domain name xxx.net
ip name-server 192.168.1.191
ip name-server 176.9.1.236
ip cef
no ipv6 cef
cts logging verbose
license udi pid xxxx
redundancy
no cdp run
interface GigabitEthernet0/0
description this is towards modem!
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface GigabitEthernet0/1
description inside network!!
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp chap hostname xxxxxxx
ppp chap password 0 xxxxxxxx
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static udp 192.168.1.191 53 interface Dialer1 53
ip nat inside source static tcp 192.168.1.191 53 interface Dialer1 53
ip default-network 193.162.105.108
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/1
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 23 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
password zzzzz
login
transport input ssh
scheduler allocate 20000 1000
end
dialer pool 1
dialer-group 1 <<- this missing
dialer-list 1 protocol ip permit <<- this missing
5 Replies 5
dialer pool 1
Many thanks. I tried that but it did not help.. still the same issue..
Remove ip nat outside from dialer interface and add it under g0/0
Hello @tkalfaoglu,
Please verify if there are active translations for the internal DNS server (192.168.1.191) and if the translations have been properly set up: #sh ip nat translations
Best regards
tkalfaoglu
THANK YOU, it works now
