NAT Configuration issue between Cisco ASR 901 routers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-19-2020 11:09 PM
Below is the simple illustration of the current lap setup.
ISP <------->OfficeRouter<------GI0/1--------->GMRTR01<-------SFP---->GMRTR04<----Gi0/1--->Laptop
192.168.2.2/16 (vlan100) 172.16.1.1/16 (vlan200) (vlan100)172.16.4.1/16 172.16.4.10
The issue which I am having right now is I am unable to reach internet / DHCP server / office Gateway from GMRTR04 however I am able to reach internet/ DHCP server / office Gateway from GMRTR01
GMRTR01 logs which is connected to Home Office router
GMRTR01#sh ver
Cisco IOS Software, 901 Software (ASR901-UNIVERSALK9-M), Version 15.6(XE318_PROD_NIGHTLY_201809071237)SP, EARLY DEPLOYMENT NIGHTLY BUILD, synced to V156_2_S_FC4
Copyright (c) 1986-2018 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 15.6(2r)SP4, RELEASE SOFTWARE (fc1)
GMRTR01 uptime is 20 minutes
System restarted at 13:03:58 IST Tue Oct 20 2020
System image file is "flash:regression_image"
Last reload type: Normal Reload
Last reload reason: power-on
GMRTR01#sh run int gi0/1
Building configuration...
Current configuration : 167 bytes
interface GigabitEthernet0/1
no ip address
no ip route-cache
negotiation auto
service instance 100 ethernet
encapsulation untagged
bridge-domain 100
end
GMRTR01#sh run int ten0/1
Current configuration : 197 bytes
interface TenGigabitEthernet0/1
no ip address
no ip route-cache
qos-config scheduling-mode min-bw-guarantee
service instance 200 ethernet
bridge-domain 200
end
GMRTR01#sh run int vlan100
Current configuration : 112 bytes
interface Vlan100
ip address dhcp
ip nat outside
bridge-group 100
bridge-group 100 spanning-disabled
end
GMRTR01#sh run int vlan200
Current configuration : 129 bytes
interface Vlan200
ip address 172.16.1.1 255.255.0.0
ip nat inside
bridge-group 200
bridge-group 200 spanning-disabled
end
GMRTR01#sh ip int bri
GigabitEthernet0/1 unassigned YES NVRAM up up
TenGigabitEthernet0/1 unassigned YES NVRAM up up
Vlan100 192.168.2.88 YES DHCP up up
Vlan200 172.16.1.1 YES NVRAM up up
NAT Configuration with default routeGMRTR01#sh run
!!ip nat inside source list ASTROME_NAT interface Vlan100 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 dhcp
ip access-list standard ASTROME_NAT
permit 172.16.0.0 0.0.255.255
bridge 100 route ip
bridge 200 route ip
GMRTR01#sh ip route
Gateway of last resort is 192.168.2.2 to network 0.0.0.0
S* 0.0.0.0/0 [254/0] via 192.168.2.2
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.0.0/16 is directly connected, Vlan200
L 172.16.1.1/32 is directly connected, Vlan200
C 192.168.0.0/16 is directly connected, Vlan100
192.168.2.0/32 is subnetted, 1 subnets
L 192.168.2.88 is directly connected, Vlan100
GMRTR01#ping 172.16.4.1
Sending 5, 100-byte ICMP Echos to 172.16.4.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
GMRTR01#ping 172.16.4.10
Sending 5, 100-byte ICMP Echos to 172.16.4.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
GMRTR01#ping 192.168.2.15
Sending 5, 100-byte ICMP Echos to 192.168.2.15, timeout is 2 seconds:
GMRTR01#ping 192.168.2.2
Sending 5, 100-byte ICMP Echos to 192.168.2.2, timeout is 2 seconds:
GMRTR01#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/12 ms
GMRTR01#ping 8.8.8.8 source vlan 100
Packet sent with a source address of 192.168.2.88
GMRTR01#ping 8.8.8.8 source vlan 200
Packet sent with a source address of 172.16.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/8 ms
GMRTR04 logs which is connected to GMRTR01 router
GMRTR04#sh ver
Cisco IOS Software, 901 Software (ASR901-UNIVERSALK9-M), Version 15.5(1)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 11-Nov-14 22:26 by prod_rel_team
GMRTR04 uptime is 32 minutes
System restarted at 01:23:07 UTC Tue Oct 20 2020
System image file is "flash:asr901-universalk9-mz.155-1.S"
GMRTR04#sh run
!ip route 0.0.0.0 0.0.0.0 172.16.1.1
GMRTR04#sh run int gi0/1
Current configuration : 148 bytes
no ip address
negotiation auto
bridge-domain 100
end
GMRTR04#sh run int ten0/1
Current configuration : 133 bytes
no ip address
bridge-domain 100
end
GMRTR04#sh run int vlan 100
Current configuration : 114 bytes
interface Vlan100
ip address 172.16.4.1 255.255.0.0
bridge-group 100
end
GMRTR04#sh ip int bri
Vlan100 172.16.4.1 YES NVRAM up up
GMRTR04#sh ip dhcp binding
Bindings from all pools not associated with VRF:
IP address Client-ID/ Lease expiration Type State Interface
Hardware address/
User name
172.16.4.10 54ee.754f.180e Infinite Manual Active Unknown
GMRTR04#sh ip route
Gateway of last resort is 172.16.1.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 172.16.1.1
C 172.16.0.0/16 is directly connected, Vlan100
L 172.16.4.1/32 is directly connected, Vlan100
GMRTR04#ping 172.16.4.10
GMRTR04#ping 172.16.1.1
Sending 5, 100-byte ICMP Echos to 172.16.1.1, timeout is 2 seconds:
GMRTR04#ping 192.168.2.88
Sending 5, 100-byte ICMP Echos to 192.168.2.88, timeout is 2 seconds:
GMRTR04#ping 192.168.2.2
Success rate is 0 percent (0/5
Laptop(172.16.4.10) logs which is connected to GMRTR04 router port Gi0/1
$ route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
172.16.0.0 0.0.0.0 255.255.0.0 U 0 0 0 enp3s0
$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 52:ff:ee:4f:18:11 brd ff:ff:ff:ff:ff:ff
inet 172.16.4.10/16 brd 172.16.255.255 scope global dynamic enp3s0
valid_lft 84447sec preferred_lft 84447sec
inet6 fe80::6180:654e:6bc:ef92/64 scope link noprefixroute
$ ping 172.16.4.1 -c 4
PING 172.16.4.1 (172.16.4.1) 56(84) bytes of data.
64 bytes from 172.16.4.1: icmp_seq=1 ttl=255 time=0.419 ms
64 bytes from 172.16.4.1: icmp_seq=2 ttl=255 time=0.482 ms
64 bytes from 172.16.4.1: icmp_seq=3 ttl=255 time=0.492 ms
64 bytes from 172.16.4.1: icmp_seq=4 ttl=255 time=2.77 ms
--- 172.16.4.1 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3100ms
rtt min/avg/max/mdev = 0.419/1.039/2.765/0.996 ms
$ ping 172.16.1.1 -c 4
PING 172.16.1.1 (172.16.1.1) 56(84) bytes of data.
64 bytes from 172.16.1.1: icmp_seq=1 ttl=255 time=0.429 ms
64 bytes from 172.16.1.1: icmp_seq=2 ttl=255 time=0.430 ms
64 bytes from 172.16.1.1: icmp_seq=3 ttl=255 time=0.382 ms
64 bytes from 172.16.1.1: icmp_seq=4 ttl=255 time=0.505 ms
--- 172.16.1.1 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3083ms
rtt min/avg/max/mdev = 0.382/0.436/0.505/0.044 ms
- Labels:
Other Routers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-19-2020 11:48 PM
post the full running configurations (sh run) of both the GMRTR01 and the GMRTR04 router. Also, what brand/model is the 'Office Router' ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-20-2020 12:19 AM
Thank you for your response @Georg Pauwen . Office Router is DLink DIR 890L. Configuration of GMRTR01 and GMRTR04 has been attached.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-20-2020 12:51 AM
thanks for the configs. What is the purpose of the bridging ? I don't see any BDI interfaces, so I am not sure what you are trying to accomplish.
Either way, looking at the below, you have IP addresses from the same address space (172.16.0.0/16) configured on two different Vlans.
GMRTR01
interface Vlan200
ip nat inside
bridge-group 200
GMRTR04
interface Vlan100
bridge-group 100
What are your two ASR routers supposed to do ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-20-2020 01:39 AM - edited 10-20-2020 01:51 AM
@Georg Pauwen the reason which we used same network on both asr router is to avoid routing.
Two ASR router purpose
Laptop connected at ISP end is suppose to transfer data from isp to the other ASR router connected to the laptop end.
This is the current lap setup where cisco asr router are connected using SFP cable which we would be removing when deploying it on the field and the data would be transferred wirelessly to the other end using our company's device.
And since data from one end needs to be transferred over other end we thought it would be simpler to keep them in the same network and avoid the complexities on routing protocols.
Having them in same network would it cause any issue for what we are trying to accomplish?
GMRTR01#sh arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 172.16.1.1 - 4c00.8287.1d6c ARPA Vlan200
Internet 172.16.4.1 3 e02f.6d74.ef5c ARPA Vlan200
Internet 192.168.2.1 0 9c3d.cf53.6f7e ARPA Vlan100
Internet 192.168.2.2 0 6c72.203d.c91c ARPA Vlan100
Internet 192.168.2.15 8 c85b.764c.cd8b ARPA Vlan100
Internet 192.168.2.88 - 4c00.8287.1d6c ARPA Vlan100
GMRTR01#
GMRTR04#sh arp
Internet 172.16.1.1 3 4c00.8287.1d6c ARPA Vlan100
Internet 172.16.4.1 - e02f.6d74.ef5c ARPA Vlan100
GMRTR04#
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-20-2020 03:07 AM
if you want to bridge Vlans, the IP addresses need to be in the same subnet.
It is probably the easiest to just change Vlan 100 to Vlan 200 on the GMRTR04 router:
interface Vlan200
bridge-group 200
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-20-2020 04:28 AM
@Georg Pauwen We have made the encapsulation as untagged on the interface config.
I have made the changes as you had asked
GMRTR04#sh run int ten 0/1
no ip address
bridge-domain 200
end
GMRTR04#sh run int vlan 200
interface Vlan200
bridge-group 200
end
GMRTR04#sh ip int brief
GigabitEthernet0/1 unassigned YES NVRAM down down
Vlan200 172.16.4.1 YES manual up up
Success rate is 0 percent (0/5)
GMRTR04#sh ip route
L 172.16.4.1/32 is directly connected, Vlan200
Still unable to ping the gateway and beyond from GMRTR04 but able to from GMRTR01
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/6/8 m
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-20-2020 06:14 AM
unfortunately I don't have two ASRs to test this on, but I think you might be missing the rewrite ingress part. Try and configure the interface configurations below:
no ip address
no ip route-cache
negotiation auto
encapsulation dot1q 100
rewrite ingress tag pop 1 symmetric
bridge-domain 100
no ip address
no ip route-cache
encapsulation dot1q 200
bridge-domain 200
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-21-2020 12:35 AM
Hello @Georg Pauwen
As soon as I add the below config
Current configuration : 206 bytes
no ip address
no ip route-cache
negotiation auto
bridge-domain 100
end
GMRTR01#sh run int ten 0/1
Current configuration : 236 bytes
no ip address
no ip route-cache
bridge-domain 200
end
Vlan100 went down
Vlan100 unassigned YES DHCP up up
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-21-2020 12:52 AM
what if you leave GigabitEthernet0/1 as it was and just change the configuration of TenGigabitEthernet0/1:
no ip address
no ip route-cache
negotiation auto
bridge-domain 100
no ip address
no ip route-cache
bridge-domain 200
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-21-2020 12:25 PM - edited 10-21-2020 12:34 PM
Hello
As the office router looks like its already doing NAT (vlan 100) and you don't want to implement routing between vlan 100 and 200 why are you trying to bridge both vlans, I would have thought you would just want to bridge vlan 200 between GMRTR01 -GMRTR04 and its end host?
Kind Regards
Paul
