NAT Configuration require
Dhiraj Jagdale
We have 4 no. of internal servers need to access from outsite(internet) by using single public ip address. need NAT configuration for cisco router.
As I read the original post the requirement is that 4 servers in the private network need to be accessible from the Internet. If that is not correct than I hope that the original poster will provide correction. What they need to be accessible from the Internet is a static translation and not the dynamic/PAT that is suggested by Mark. And if there is only a single public IP address then it needs to be done with port forwarding where the port is identified and not by a simple static NAT. It might look something like this
ip nat inside source static tcp 10.1.2.250  25  1.2.3.4  25  extendable
ip nat inside source static tcp 10.1.2.251  80  1.2.3.4 80  extendable
ip nat inside source static tcp 10.1.2.252  110  1.2.3.4 110  extendable
ip nat inside source static tcp 10.1.2.253  443  1.2.3.4 443  extendable
Note that this works if each of the 4 servers provides a unique service but would not work if 2 of the servers are offering the same service (like 2 servers providing HTTP).
Rick
Rick
Mark Malone
example
ip nat inside source list 111 interface fa4 overload
access-list 111 permit ip 192.168.0.0 0.0.0.255 any
ip nat inside -----on lan interface or vlan
ip nat outside----- on wan interface or dialer
Rick
Rick
Thanks Richards.....
