NAT configuration with IE2000 8TC-G
MK1603
I want to configure a simple NAT configuration on an IE2000 8TC-G router.
Is this possible with the Cisco Network Assistant? I didn't find there a possibility. Therefore, it seems to be possible only on the USB console? The WEB frontend isn't working on my model, don't know why.
Or is there another possibility to configure NAT?
My NAT config is very simple:
External (g1/1):
IE2000: 10.100.10.1
PC1: 10.100.10.2
PC2: 10.100.10.3
PC3: 10.100.10.4
PC4: 10.100.10.5
Gateway: 10.100.10.8
Internal (po1/8):
IE2000: 192.168.0.1
PC1: 192.168.0.2
PC2: 192.168.0.3
PC3: 192.168.0.4
PC4: 192.168.0.5
That's all.
Any idea how to configure this in Cisco Network Assistant?
Moritz
the IE2000 supports L2NAT, I don't think you can configure it with CNA, so you have to do it though the command line.
