NAT failover with DUAL Leased lines on 1841 router
We have 1841 router with HWIC-4ESW we need to config point to point data Dual leased lines failover concept please find attached diagram.
cadet alain
if you're not running any IGP then just  create a floating static route for the backup link( with an AD > 1 and < 255).
Regards.
Alain
patrick.preuss
Hi Raja
depends on what you want to realize.
May Be you have a look into route-map based nat, with this you can realize connectivity with dual isps.
Patrick
Marwan ALshawi
for dual interface with nat
after you sort out your routing using either IGP or static route
you need to consider using a route map with each nat command to address the exist interface as described in the document below / nat section
https://supportforums.cisco.com/docs/DOC-8313
hope this help
if helpful rate
