NAT for locally generated traffic
sivam siva
Level 3
Level 3
I'm doing NAT in the edge router for the traffics goes to the internet, NAT is working fine but the locally generated packets are also nating  (ex: BGP packets.because of which my bgp peer is down)
If I exclude the source address of BGP packet from the access-list(called in NAT), that IP is not nating and bgp works fine.
but what is the proper way to prevent from nating the locally generated packets
can anyone help?
Thanks in advance.
6 Replies 6
Sergey Lisitsin
Hi Sivam,
I guess that happens because you are sourcing your BGP session from the IP address that is also covered by your NAT access-list. Normally that wouldn't happen as your loopback IP addresses would be chosen from a separate reserved range, that is not used anywhere else, so it wouldn't match any of the LAN access lists. I guess the proper way to avoid natting your own packets would be to re-address your source loopback to a dedicated IP address that is outside of the NAT inside range.
Hello  @Sergey Lisitsin
Thanks for the reply
Please see below-attached photo, I have peered with loopback 1 which is not NAT inside interface
then how traffic originates from loopback 1 is translated?
Hello
you should be able to negate bgp from being natted by the same all you use for nat.
Can you post the configuration of your rtr to verify .
Kind Regards
Paul
Hello @paul driver
here is the config
R1#
R1#sh run
Building configuration...
Current configuration : 4603 bytes
version 15.2
hostname R1
boot-start-marker
boot-end-marker
logging console informational
logging monitor informational
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback1
ip address 1.1.1.1 255.255.255.255
ip ospf 1 area 0
interface FastEthernet0/0
ip address 90.0.0.1 255.0.0.0
duplex full
interface GigabitEthernet1/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet2/0
ip address 10.13.0.1 255.255.255.0
ip nat inside
ip ospf 1 area 0
negotiation auto
interface GigabitEthernet3/0
no ip address
negotiation auto
interface GigabitEthernet4/0
ip address 30.19.0.1 255.255.255.0
ip nat outside
negotiation auto
interface FastEthernet5/0
ip address 10.14.0.1 255.255.255.0
ip nat inside
ip ospf 1 area 0
duplex full
interface Serial6/0
ip address 70.17.0.1 255.255.255.0
ip nat outside
serial restart-delay 0
interface Serial6/1
no ip address
shutdown
interface Serial6/2
no ip address
shutdown
interface Serial6/3
no ip address
shutdown
interface Serial6/4
no ip address
shutdown
interface Serial6/5
no ip address
shutdown
interface Serial6/6
no ip address
shutdown
interface Serial6/7
no ip address
shutdown
router ospf 1
router bgp 10
bgp router-id 1.1.1.1
bgp asnotation dot
bgp log-neighbor-changes
bgp bestpath med missing-as-worst
bgp dampening route-map DAMPENING
network 2.2.2.2 mask 255.255.255.255 backdoor
aggregate-address 200.20.0.0 255.255.0.0 as-set summary-only suppress-map SUP
aggregate-address 70.0.0.0 255.128.0.0 as-set summary-only
neighbor 3.3.3.3 remote-as 10
neighbor 3.3.3.3 update-source Loopback1
neighbor 3.3.3.3 next-hop-self
neighbor 3.3.3.3 send-community
neighbor 3.3.3.3 route-map lp out
neighbor 3.3.3.3 unsuppress-map UNSUP
neighbor 4.4.4.4 remote-as 10
neighbor 4.4.4.4 update-source Loopback1
neighbor 4.4.4.4 next-hop-self
neighbor 4.4.4.4 soft-reconfiguration inbound
neighbor 4.4.4.4 unsuppress-map UNSUP
neighbor 4.4.4.4 maximum-prefix 1 warning-only
neighbor 9.9.9.9 remote-as 30
neighbor 9.9.9.9 transport connection-mode passive
neighbor 9.9.9.9 disable-connected-check
neighbor 9.9.9.9 update-source Loopback1
neighbor 9.9.9.9 soft-reconfiguration inbound
neighbor 9.9.9.9 prefix-list EPRIZE out
neighbor 9.9.9.9 route-map WEIGHT in
neighbor 70.17.0.7 remote-as 70
neighbor 70.17.0.7 route-map INTERNETFILTER in
neighbor 70.17.0.7 route-map MED out
neighbor 90.0.0.2 remote-as 70
ip nat pool NAT 159.5.5.0 159.5.5.254 netmask 255.255.255.0
ip nat inside source list 1 pool NAT overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 9.9.9.9 255.255.255.255 30.19.0.9
ip access-list standard lp
permit 30.0.0.0 0.255.255.255
ip prefix-list 9WEIGHT seq 20 permit 0.0.0.0/0
ip prefix-list 9WEIGHT seq 21 permit 200.20.50.0/24
ip prefix-list DAMPENING seq 20 permit 150.50.50.0/24
ip prefix-list EPRIZE seq 20 permit 3.3.3.3/32
ip prefix-list EPRIZE seq 21 permit 159.5.5.0/24
ip prefix-list INTERNETFILTER seq 20 permit 0.0.0.0/0 le 32
ip prefix-list INTERNETFILTER1 seq 20 permit 8.8.8.0/24
ip prefix-list SUP seq 20 permit 200.20.20.8/32
ip prefix-list SUP seq 21 permit 200.20.30.8/32
ip prefix-list SUP seq 22 permit 200.20.40.8/32
ip prefix-list UNSUP seq 20 permit 20.20.50.0/24
logging trap debugging
access-list 1 permit any
route-map WEIGHT permit 20
match ip address prefix-list 9WEIGHT
set weight 10
route-map WEIGHT permit 100
route-map INTERNETFILTER deny 19
match ip address prefix-list INTERNETFILTER1
route-map INTERNETFILTER permit 100
route-map lp permit 20
match ip address lp
set local-preference 222
route-map lp permit 100
route-map MED permit 20
match ip address prefix-list EPRIZE
set metric-type internal
route-map UNSUP permit 20
match ip address prefix-list UNSUP
route-map DAMPENING permit 20
match ip address prefix-list DAMPENING
set dampening 1 100 399 2
route-map SUP permit 20
match ip address prefix-list SUP
route-tag notation dotted-decimal
control-plane
line con 0
exec-timeout 30000 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
line vty 5 15
login
end
R1#sh ip bgp summ
BGP router identifier 1.1.1.1, local AS number 10
BGP table version is 11, main routing table version 11
8 network entries using 1152 bytes of memory
15 path entries using 1200 bytes of memory
9/8 BGP path/bestpath attribute entries using 1224 bytes of memory
2 BGP rrinfo entries using 48 bytes of memory
4 BGP AS-PATH entries using 96 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 3720 total bytes of memory
Dampening enabled. 0 history paths, 0 dampened paths
BGP activity 8/0 prefixes, 15/0 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
3.3.3.3 4 10 14 5 11 0 0 00:02:42 8
4.4.4.4 4 10 12 5 11 0 0 00:02:33 6
9.9.9.9 4 30 0 0 1 0 0 never Idle
70.17.0.7 4 70 0 0 1 0 0 never Active
If you see below output ICMP traffics originate from outside interface also Nating , I'm wondering about that.
R1#ping 9.9.9.9 source g4/0
Sending 5, 100-byte ICMP Echos to 9.9.9.9, timeout is 2 seconds:
Packet sent with a source address of 30.19.0.1
Success rate is 0 percent (0/5)
R1#sh ip nat trans
R1#sh ip nat translations
Pro Inside global   Inside local   Outside local   Outside global
tcp 159.5.5.1:1037   1.1.1.1:179    9.9.9.9:40518   9.9.9.9:40518
tcp 159.5.5.1:1040   1.1.1.1:179    9.9.9.9:63835    9.9.9.9:63835
icmp 159.5.5.1:1024    30.19.0.1:0   9.9.9.9:0     9.9.9.9:1024
icmp 159.5.5.1:1025   30.19.0.1:1    9.9.9.9:1     9.9.9.9:1025
Sivam,
Your access-list for NAT has permit any in it, that's why everything is matching. Just match on what you need in the ACL and you will be OK. For example, your NAT ACL should look like this:
access-list 1 permit 10.13.0.1 0.0.0.255
access-list 1 permit 10.14.0.1 0.0.0.255
That will do and won't cause any issues with natting anything else, that should not be natted.
@Sergey Lisitsin
Thanks for the reply.
I agree that we must write access-list only for the needful address,
for some reason I want to permit all inside IPs  to nat, assume there might be thousands of address inside the network so I configured "permit any "
My doubt is the how traffic originates from a loopback interface (which is not configured NAT in/out) translated,  and traffic originates from the outside interface (int s6/0)  is Translated,
even if I generate ICMP that packet source address also translated.
